Old 10-09-2023, 08:58 AM   #11
Billy Nees
Liked 7,762 Times in 1,741 Posts
Default Re: Flat tappet lifter failure
Originally Posted by Terry Cain View Post
If the rule were changed I doubt it would say you have to run the roller lifter.
Are you delusional? If you're running a big-block anything in Stock then you're in a highly populated class. If the rule is changed then your competitors WILL take advantage of it meaning you WILL be forced to take advantage of it or you will not be competitive.
Billy Nees 1188 STK, SS
