Old 11-20-2022, 10:07 AM   #1
mike britt
Liked 66 Times in 31 Posts
Default Sbc headers.
Anybody ever try a header with a flat 4 collector anstead of square 4? Just wondering if it is a good or bad idea.
mike britt is offline   Reply With Quote
Old 11-20-2022, 10:26 AM   #2
Billy Nees
Default Re: Sbc headers.
It's been tried, not such a good idea.
Billy Nees 1188 STK, SS
Old 11-20-2022, 11:43 PM   #3
Jim Caughlin
Liked 805 Times in 245 Posts
I have used them but only for ground clearance issues. No way this is going to improve performance.
Jim Caughlin is offline   Reply With Quote
Old 11-21-2022, 05:22 AM   #4
Mike Jones
Liked 684 Times in 289 Posts
On the subject of collectors, I have a pair of 4-2-1`s. I thought about merging them to a cheap set of headers. Thoughts ?
Old 11-21-2022, 08:26 AM   #5
Billy Nees
If you can get them phased correctly they may show you something.
Old 11-23-2022, 12:27 PM   #6
Liked 5,134 Times in 1,958 Posts
Used to be readily available...Not so much anymore.
Old 11-23-2022, 06:57 PM   #7
Mike Jones
Mark,
Have you tried them?
I got a pair from Wojo when I got his old wagon.. He said he never used them. I did put longer collectors on, per Al Peters, and that was worth .05
I expect it would pick up the bottom, but how much?
Old 11-25-2022, 08:31 PM   #8
Henrys Toy
Liked 520 Times in 176 Posts
Smile Re: Sbc headers.
Good evening to all,
I'm still using my Flowmaster 4-2-1 collectors, be for warned if you're going to use them with a " tight " lobe seperation , they don't work well with that.
The flowmasters seem to like a little wider lobe seperation angle. The Burns style collector works better with a tight lobe seperation. At least tha'ts what I've found over the years, and you have to try some adjustments to get everything from them.
Respectfully,
Henry Kunz 1534 H/SA
Henrys Toy is offline   Reply With Quote
Old 11-26-2022, 10:29 AM   #9
Charlie Yannetti
Liked 192 Times in 83 Posts
I was going to recommend a consult with Billy Nees.. BUT, it kinda sounds like he's been there, done that...
Charlie Yannetti is offline   Reply With Quote
Old 11-29-2022, 02:40 PM   #10
rod
Liked 20 Times in 15 Posts
Greg, at REF in Kingman, AZ says: they work for low comp. motors. not so good on higher comp. he said the 305/307 Chevy and small Olds engines would be OK, but not at real high RPM. [although, I dont know what high RPM would be in those]
Rod in AZ
rod is offline   Reply With Quote
