Old 07-23-2022, 10:37 AM   #1
Rick J
Liked 73 Times in 37 Posts
Default Re: Engine hone question
The TS rings are too hard for production blocks typically, and no the hone won't fix it properly regardless of what TS says. More RVK in the hone surface will help, but then you're creating unnecessary friction.
Mahle's HV385 top ring is the best choice for any block, production or aftermarket, if your bore size, width, and radial are available.
Good Luck
Rick J is offline   Reply With Quote
Old 07-23-2022, 07:15 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Check the oil ring tension. If it is too light it will pump oil like crazy. Do you have oil in the intake manifold?
Mike Pearson 2485 SS
Old 07-24-2022, 12:29 PM   #3
340Cuda
Liked 804 Times in 341 Posts
I would get in touch with one of these guys, they may be able to recommend a couple of shops as well as tell you how you should hone the cylinders.
Keith Jones
Director of Technical Sales
keithj@totalseal.com
Lake Speed, Jr.
Vice President Sales & Marketing
lake@totalseal.com
Old 07-24-2022, 12:32 PM   #4
richard diorio
Liked 15 Times in 5 Posts
Brush hone with 220 grit use same old rings
richard diorio is offline   Reply With Quote
Old 07-26-2022, 02:14 PM   #5
NSSGTO
NSSGTO's Avatar
Liked 24 Times in 17 Posts
Agree, have done this a few times with production blocks. We used to run them in on the dyno then brush hone afterwards and reassemble with same rings.
NSSGTO is offline   Reply With Quote
Old 07-26-2022, 03:12 PM   #6
Rick J
Rings make the bore round.
Old 07-26-2022, 05:30 PM   #7
B/S 428
Liked 154 Times in 34 Posts
I use leak down and compression check along with obviously is it smoking? Light weight ring pacs can have a inaccurate reading on leak down..I ultimately make my final decision using compression test. If it has say 200# on all cylinders, I'm not to concerned with leak down numbers..JMO Brian Seaberg 627
B/S 428 is offline   Reply With Quote
Old 07-26-2022, 05:34 PM   #8
Bob F
Liked 16 Times in 11 Posts
After you brush hone do you use the deburring brush?
Bob F is online now   Reply With Quote
