Old 04-08-2022, 12:39 AM   #1
CMcAllister
Liked 920 Times in 259 Posts
Default Re: accusump plumbing
I use an electric valve mounted on the accusump. They replace the manual ball valve if that's what you are asking. One advantage is the electric valve will allow the can to charge when it is off but not allow oil to go back to the engine until it is turned on.
I use a dedicated switch to control the valve as desired.
Pre-oil the engine before cranking if it has been sitting overnight or longer. Turn it off once the engine is running to allow it to refill. Leave it off until I roll into the water. Turn it on at that point and leave it on until after making the turn off. Turn it off at that point and leave it refill the can while driving back to the trailer and back to the lanes.
Also useful for pre-oiling a fresh engine. Just have to fill, assemble and charge it, usually out of the car.
That was my routine.
CMcAllister is online now   Reply With Quote
Old 04-08-2022, 06:59 AM   #2
hrs1326
Liked 19 Times in 10 Posts
al always you guys are very helpful, I appreciate the info
race on!
hrs1326 is offline   Reply With Quote
Old 04-08-2022, 08:51 AM   #3
Signman
Liked 269 Times in 99 Posts
Have one of the Moroso valves will part with.
PM with a fair offer
