Old 11-01-2021, 11:29 AM   #28
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Default Re: Stock Auto Trans Rule Change History ?
"...if that Pontiac combination could run 11.00 or under it would be pretty good..."
Since Adam Strang ran 10.80's, with a stick, I assume that same engine would run somewhere around that 11 sec number, with the correct auto trans set-up.
The E/SA index is 11.70.
http://www.classracerinfo.com/NHRA_Classes.aspx
So, an 11.00 car would be competitive, at most races. Wouldn't make the 128 field @ Indy. And wouldn't win the heads-up runs against the really quick E/SA cars. But, it would win some heads-up runs, & would have a chance to win any race in which it didn't have a heads-up round.
.700 under would have been just below the middle of the field @ the recent div 2 race.
https://www.dragracecentral.com/DRCS...r=100#indextop
If my calculations are correct, the 350 '68 Bird is a natural F-class car. Can add some weight & run G/SA. 11 x 305 = 3355lb
The G/SA index is 12-flat. So, anything quicker than 11.50 would be fairly competitive. Low 11's would win some heads-up rounds.
Could remove some weight & run E/SA. 10 x 305 = 3050lb. So, that would be about 300lbs difference.
I think you must add 170lbs for driver, to arrive at the min total weight for the class you'll run. So min weight for E/SA would be 3050 + 170 = 3220lbs. For G/SA, it would be 3355 + 170 = 3525lbs.
