Old 06-18-2021, 09:31 PM   #11
SS BRP
Default Re: Best cam for E7 Heads
Originally Posted by Greg Hill View Post
So let me get this straight. You want to build a street-strip, period correct, from the 90’s Mustang Super Stock look alike? Are you going to back halve the car? Roll cage? If it doesn’t have to be legal you could run a bigger motor. Good luck on what you do, although asking about what cam you should run is not something you’re going to find out here.
Well no I still want it to conform to the rules of Super Stock, so I wouldnt run a bigger motor or different heads. Just like if this was the 1990’s and I was to build a super stocker. Like a throw-back build.
SS BRP is offline   Reply With Quote
Old 06-22-2021, 08:55 AM   #12
427FE
427FE's Avatar
Liked 348 Times in 79 Posts
Even a throw back build wouldnt be streetable.
427FE is offline   Reply With Quote
Old 06-22-2021, 11:43 AM   #13
Liked 5,140 Times in 1,962 Posts
1st, There weren't many Fox body S/S cars out ther 25 years ago. The HP rating was not favorable.There were a few FE SS/GT cars.
2nd, Back halfing or at least tubbing for 14/32's started in the late 70's, so I've got to ask if you are going to drive around the streets on 14/32 slicks?
Old 06-25-2021, 10:02 AM   #14
fordteacherguy
Liked 160 Times in 51 Posts
Thumbs up Re: Best cam for E7 Heads
Put a pro street grind in it that will clear the existing pistons, tall valve covers, an aftermarket intake and some10.5x28s and call it good.
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 06-28-2021, 01:57 PM   #15
fordteacherguy
Bret,
Sent you a PM.
Brian Thompson
Old 06-29-2021, 07:20 PM   #16
Capri
Liked 27 Times in 14 Posts
Period correct 5.0. You will spend about 30 grand to get close if you plan to try racing under the index. IF anyone will give you a Cyl head profile and a for real SS camshaft design. Forget using a stock block. Im sorry to say, this is not something you really wish to do. We spent tons trying to make SBF stuff go fast. And thats all now outdated.
Capri is offline   Reply With Quote
Old 06-29-2021, 07:29 PM   #17
Lee Valentine
Liked 319 Times in 68 Posts
Sounds like an exercise in kissing your sister.
Lee Valentine 1661 STK
Old 07-01-2021, 10:10 AM   #18
BRETV
Liked 776 Times in 199 Posts
Originally Posted by SS BRP View Post
617. Cam with stock E7 heads? Didnt even know that was possible. Ive driven some pretty extreme cars on the street, as long as you have an over drive gear its not so bad, I would be staying with a 5 speed.
Sorry, told you wrong on the cam lift. I looked back at my notes, it was .745
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
Old 07-02-2021, 07:12 AM   #19
Ralph A Powell
Liked 226 Times in 137 Posts
And a few 351 Cleveland motors also!
