#11 |
Liked 3,177 Times in 971 Posts
#12 |
Liked 205 Times in 93 Posts
oh man have tried a bunch...5.5lbs. pressure, holes in butterflies, leaned idle air bleads a couple, jetting is in reason. floats just below sight plug. maybe could lower? plugs r cleaner after a non stop tour...
#13 |
Liked 16 Times in 11 Posts
Idle fuel bleeds are too large.
#14 |
Liked 347 Times in 151 Posts
Yes, idle feed restrictions could be a bit large. Did you plug the secondary P.V. and go up 5 or 6 numbers? How much base timing, and total?
Phil Molski PMR Performance S/C 1623 |
#15 |
Liked 2 Times in 2 Posts
Do you have a power valve in the carb or is it blocked off ?
#16 |
950 holley HP. nice carb..... 3.5 pv, timing @ 18 inital/35 total. (pump gas)
#17 |
You said 8 inches of vacuum at idle. Was the car in drive or in park when checked ? I always adjust the carb, idle mixture vacuum etc. in drive. Being in park raises the rpm and vacuum readings. Just checking because if overlooked it will not be an optimized setting of the carb. Good luck.
#18 |
idle fuel bleeds? theres idle air jets that ive gone up #75 tp 78...yes slick5681 did vacume check proceedures in drive...
#19 |
found them...checking sizes
#20 |
thankyou everyone for all you help. best i can measure today is .090'' on the idle feed restrictor....this restrictor i was unaware of, therefore its factory size and untouched.
