Old 07-20-2020, 11:56 AM   #1
68Coupe
Default Question about converter stall and fallback
I know every combo is different but for you guys running 3 speed automatics what kind of fallback do you want from your shift point.
Reason I’m asking is I feel my converter is too loose with my new motor. It runs good but I think it’s loose but don’t know if it’s worth making a change.
This is only a bracket car but I’m shifting at 6400 and it’s only falling back to 6000.
Just looking for opinions/suggestions.
68Coupe is offline   Reply With Quote
Old 07-20-2020, 03:16 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: Question about converter stall and fallback
That's a million dollar question and answer, what's your converter slippage % in high gear?
Gear ratio ,hp and tire size comes in to play,
It might take a couple of adjustments in the converter to find what works the best
Old 07-20-2020, 03:24 PM   #3
68Coupe
1/8th mile bracket car only.
it runs low to mid 6.50's weighs 3100 w/driver don't know horsepower. It has 4.86 gear and 29x10 slicks and crosses @6400
Old 07-20-2020, 06:23 PM   #4
L.Fite
Liked 497 Times in 243 Posts
It would be good to know where it makes peak torque and HP, 6000-6400 sounds like a pretty narrow band to work in.
Hard to say otherwise.
L.Fite is offline   Reply With Quote
Old 07-20-2020, 07:52 PM   #5
Bob Shaw
Liked 317 Times in 62 Posts
I think the rpm should fall back to where the engine makes peak torque after the shift.
There is only one way to know for sure.
Bob Shaw V/SA 515
Bob Shaw is online now   Reply With Quote
Old 07-20-2020, 11:14 PM   #6
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
If it goes 105 mph the converter is slipping 7% 4.86 gear 29 tire.
105 mph is my guess of what it goes, typical mph for 6.50 et, in order to do the equation.
7% is good 1/8 mile but stall is high for 6400 shift, should be around 5000 - 5200 stall 3 speed transmission shifting 6400 rpm.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 07-21-2020, 03:08 AM   #7
Adger Smith
Liked 880 Times in 311 Posts
I have noticed with customers that every converter/combination is slightly different. Some don't like to hang, some do. Just have to do some testing to get it right.
Adger Smith (Former SS)
