#11 | |
Liked 5,153 Times in 1,967 Posts
However, if you're a hands on type, with metal working skills and tools, there's lots of places where you can removed a pound or two, and not be noticed. If you're a checkbook / bubble pack racer, you're just going to have to open the wallet wide and kick it out..It's only money.
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 04-19-2019 at 07:04 PM. |
#12 |
Liked 354 Times in 120 Posts
Look for after market glass, steering gear, steering shaft. Tom
Tom Meyer 5240 SS Stock ??? |
#13 | |
Liked 26 Times in 11 Posts
#14 |
Liked 205 Times in 93 Posts
#15 | |
Liked 1,987 Times in 599 Posts
No issues with the lithium battery. You do have to take care of it charge wise. It charges quick usually about 20 minutes after the run. I have a Go Lithium brand battery and charger. Check with them as they run specials every so often the battery is about $600 plus the charger. I have been using it for about 5 years. I only run one of them and have not had any issues with power in the late rounds. I carry a pony battery in the trailer to run the water pump and fan to cool the car after the run while the lithium battery is charging.
Mike Pearson 2485 SS |
#16 |
Liked 888 Times in 239 Posts
Seats,front and rear ,wiring harness, sound deadener , factory carpets ,all the unnecessary underdash stuff ,} defroster ducts and dash controls must stay }are the biggest gain for the least expense.
Door guard beams are also good for quite a bit of weight . Aluminum bolts and screws on non suspension parts can reduce as much as 15 - 20 # on big cars. using the shortest bolts possible elsewhere all adds up. Getting rid of the factory fuel tank in favor of a 3 gallon cell and pump is a big weight loss, but will take several hundred bucks from the budget. . On the more pricy side are the lithium batteries ,but the weight savings are huge and when getting to the last 30-40 # is necessary an expense that may need to be taken. I've had very good results using batteries from Antigravity Battery . You mentioned adjustable seats , unless drastically different size drivers are going to be running the car, a waste of both money and weight . Some modern steering wheels are are very heavy to dampen vibration, and to frevent breakage during airbag deployment . Ive found light wheels that weigh as little as 1 3/4 pounds [Stock car stuff]
#17 |
Liked 167 Times in 81 Posts
Tim Schmackpfeffer 762 SS |
#18 | |
Liked 1,443 Times in 302 Posts
If you thought sound deadner was a necessary part of a stocker you need to re think your goals. Seriously, scrape that off and read the thread. Some great commons sense ideas here
James Schaechter 3163 STK |
#19 |
Actually ,a lot of the glass for older cars is substantially thinner {i.e. more cheaply made] and not as expensive as O.E glass.
I've seen some windshields that came from Mexico , China and South Africa that were 12 -15 pounds lighter than original and were not overpriced . Optical quality ,sometimes I've had to say no ,get me another one . I put one in an AMX that was actually 18# lighter than an O.E.
