Old 07-11-2020, 04:51 PM   #1
GTX JOHN
Liked 2,483 Times in 697 Posts
Default Re: Jumping in to Stock Eliminator
There are a dozen 360 combos that are good
in the Ram trucks. I have run 1.5+ under with them
on a budget.
The 318 combo are few and not very good.
It is better in a F body Mopar.
I do have a 360 Combo Truck N/SA for $9,500 turnkey or
$7,000 rolling that is finished.
John Irving
741 Stock
741 Super Stock
Old 07-11-2020, 05:09 PM   #2
Dragrac419
Liked 183 Times in 82 Posts
on a budget.
This my second year running stock and I can tell you buy a car or Truck already built. This is a great price for something running and you will have way more fun right off the bat. I will say listen to the guys that have been around as most will give you good advice. I have a couple people that I bug for different tips that I should try.
Good luck with what ever you choose and hope to see you at the races soon.
Brian
Stk B200
Dragrac419 is offline   Reply With Quote
Old 07-11-2020, 08:51 PM   #3
Jared Jordan
Liked 534 Times in 118 Posts
Send a message via AIM to Jared Jordan
on a budget.
Guarantee you won’t build your truck for what you could buy this one for and the Irving Family are top notch good guys that can help you out with it too.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 07-11-2020, 09:16 PM   #4
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: Jumping in to Stock Eliminator
I second that statement exactly. Even if you just got done building a stocker, it takes several months or a year to sort it out, get the hang of driving it, and start winning rounds. Yes the Irvings would help you and get you there sooner.
Old 07-11-2020, 09:27 PM   #5
Dave Gantz
Liked 251 Times in 125 Posts
With a "built" vehicle, you can get right into testing, tuning, experimenting. That's what Stock is all about.
Used to be, you bought a used street vehicle and made it a race car. Now, it's classic car stock racing. To build from scratch, you'll either have to spend considerable bucs just to get a nice original vehicle, or spend considerable bucs to make a dog nice enough to THEN spend modifying it.
Heck, now days, just a paint job can cost more than what it used to cost to buy and build a competitive car. (depending on class, a bit)
Geez, I'm talking myself into an already done car! But I'm a recovering addict and wwwwwwill not ggggget into it aaaaaaagain....
Old 07-11-2020, 10:44 PM   #6
Dave Noll
Dave Noll's Avatar
Liked 239 Times in 112 Posts
Well I guess I will go against the grain. I have 2 LOWER class cars that I've assembled myself. My "N" car has only run .45 Over. My "EF" car has already run .51 under. Part of this Stock deal is picking a good combo. I like the technical part of this and seeing what works and what doesn't. Which probably goes against what my wallet can afford.? But to me , this way is more gratifying.
Dave Noll, EF/S ,?/SA 6526
Old 07-12-2020, 08:02 AM   #7
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
on a budget.
Sounds like a lot of money saved over building one. You can make it your own afterwards but a sorted prepared race vehicle saves you thousands over R&D of your own stuff
Old 07-12-2020, 12:12 PM   #8
Wayne Scraba
Liked 186 Times in 48 Posts
Smile Re: Jumping in to Stock Eliminator
Although it's not a Stock Eliminator car, you might find this interesting:
Recently, I quickly added up the invoices for suspension, steering, wheels, tires and brakes on my Nova street machine. I'm a Canadian, but all of the prices were in US dollars, without shipping or taxes. The total was north of $9250 and that doesn't include the rear end assembly. That's for a leaf spring car that is similar to a stocker. There's one caveat: I did use Detroit Speed upper and lower a-arms ($1400 or so), but if it was a stock eliminator car, I still would have had bushings, ball joints and mods to install the shocks to deal with.
What I'm getting at is you can end up with a lot of $$$ in what seems like a simple rebuild, if you decide to use good quality parts.
Just food for thought....
Wayne Scraba is offline   Reply With Quote
Old 07-12-2020, 12:58 PM   #9
Signman
Liked 269 Times in 99 Posts
There is a lot to be said with building your own stocker you must have the equipment, skills, drive and time.
The satisfaction of getting it to the track (which most never do) then racing it and being successful can not be beat. It's what Stock is all about!
When buying an existing car the good cars are not cheap and the cheap cars are not that good. Of course high / low price is relative to the class and combination.
The Pickup Truck above if you're OK with the class it fits is probably the buy of the year seeing who built it. Meet at the track watch it run and take it home.
Old 07-12-2020, 04:03 PM   #10
Jeff Stout
Liked 704 Times in 281 Posts
I did nearly everything on Olds Stocker and buying swap meet, ebay and having junk on shelf to use it still came to over 9k to build. Machine work on block and basic everyday head job was what I farmed out. Trans kit, bearings, gaskets, rings were about the only new items.
