Old 06-16-2020, 12:36 PM   #1
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: SS/GT classes transmission?
Mark is correct.
The transmission had to be available with the engine combination.
Other examples are the Ford Boss 302 and Boss 351; they were manual trans only.
Also, number of gears has to match, 5 speeds only if combo originally came that way.
Jim Caughlin is online now   Reply With Quote
Old 06-16-2020, 12:46 PM   #2
Bob Gullett
Bob Gullett's Avatar
Liked 504 Times in 116 Posts
If it came with a 3 speed you are allowed to run a 4 speed.
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
Old 06-16-2020, 01:26 PM   #3
Jim Caughlin
I guess I should have clarified that, but no 5 speed in an original 4 speed combo. Also, you can run a 4 speed in an orig 5 speed combo if you wish.
Old 06-17-2020, 09:31 PM   #4
Dave Noll
Dave Noll's Avatar
Liked 238 Times in 111 Posts
Uhm, is that the regular SS classes as well?
Dave Noll, EF/S ,?/SA 6526
Old 06-17-2020, 09:44 PM   #5
Ernie Neal
Ernie Neal's Avatar
Liked 326 Times in 78 Posts
Yes
Ernie Neal
SS 354
Old 06-16-2020, 01:44 PM   #6
Liked 5,120 Times in 1,951 Posts
Yes...
Old 06-16-2020, 06:15 PM   #7
mannymen
Liked 13 Times in 7 Posts
Thank you for the quick responses.
N/A
mannymen is offline   Reply With Quote
Old 06-16-2020, 08:14 PM   #8
KRatcliff
Liked 524 Times in 141 Posts
You can count on this group in a clutch.
KRatcliff is offline   Reply With Quote
Old 06-16-2020, 10:56 PM   #9
Hacksaw
Liked 310 Times in 174 Posts
The way I read the rule book it says, " any model transmission, same make as car, with a maximum of three forward speeds". To me this means you could have or a 283" Chevy in a 98 Camaro SS /GT with a 200 metric or turbo or .....
Old 06-17-2020, 11:58 AM   #10
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
I'm not sure about this. In GT weight is linked to the transmission you want to run but I'm not sure a factory match is required in the finished car.
The rules state weight is determined using the heaviest weight gas engine with appropriate transmission available. So to find the shipping weight of a car for stick or auto application, find that car's heaviest weight in either stick or auto for the weight factor.
There is no transmission section in the GT section, just shield requirements. That means you look back to SS which reads any model trans same make as body with forward gear limits. Nowhere does it state stick must be stick or auto must be auto for any flavor of SS. Adapter plates are allowed. You can bolt up a trans that's not designed for your bellhousing.
If you are allowed to drop a motor from a '60s station wagon into the "trunk" of a Cobalt, why can't you bolt an auto to a stick only engine like a '70 BOSS 302 Mustang? In one, you rebuild the entire car. In the second you change the trans/bellhousing.
Dale Shearon
68 Mustang 6394
