Old 06-01-2020, 04:16 PM   #1
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Metric 200 - What do I need to make one last
If you get the rebuild through Scott McClay , he has an option to get you a 350/400 turbine shaft , and revised pump . That way you can use your current converter .
Old 06-01-2020, 05:24 PM   #2
Bob Don
Bob Don's Avatar
Liked 903 Times in 192 Posts
Get a J.W. Performance Ultra Bell. I cracked two cases before getting one. The case is the weak link on a TH200
https://racewithjw.com/product/ultra...-metric-to-gm/
Bob Don 128 SS
Old 06-01-2020, 06:18 PM   #3
If you don't go with the 350/400 changeover option, you still want to get a hardened stator support shaft insert.
Old 06-01-2020, 08:26 PM   #4
B Parker
Liked 2,336 Times in 464 Posts
Real simple Sepanek Racing Transmissions. I have 75 runs on his metric in a Big Block Chevy stocker. It's a 1970 402/375 hp making 635 hp. It's the fastest trany I've had in my car and it has lasted. BP
Old 06-02-2020, 05:21 AM   #5
Lee Valentine
Liked 319 Times in 68 Posts
Sepanek all the way,best and fastest out there
Lee Valentine 1661 STK
Old 06-02-2020, 07:32 AM   #6
KennyAnderson
Liked 357 Times in 119 Posts
Thanks guys and keep em coming! I've been told the Metric 200 is about a tenth faster than a TH350. Hoping this is true??? I would hate to leave that on the table but I'm wrestling with the durability of the 350.
KennyAnderson is offline   Reply With Quote
Old 06-02-2020, 08:20 AM   #7
GUMP
Liked 2,354 Times in 554 Posts
A good one will be fine behind an LT1. It will also be a little faster.
Old 06-02-2020, 08:35 AM   #8
Alan Nyhus
Liked 799 Times in 236 Posts
Billy Lynn does also a great Metric 200. If you've got a TH350/400 convertor, you can have a input for those installed along with the appropriate pump mods. The governor driven auto 1-2 makes them very consistent. The JW bell housings are a worthwhile addition or you can fabricate a brace for the stock case. Also, the Lokar flexible dipstick makes life a lot easier. The marks on the Lokar unit aren't correct so you need to remark it relative to the oil pan flange on the case. Retapping the oil pan holes to 1/4X20 from the metric size is another thing to do to simplify things. If you elect to have a roller rear bearing installed in place of the bronze one, the drive shaft yoke will likely need to be turned down about .020 for proper fit.
For what it's worth. -Al
Billy Lynn (501) 278-0651
"That'll never work....."
Old 06-04-2020, 08:17 PM   #9
Joe Schweigert
Joe Schweigert's Avatar
Liked 19 Times in 8 Posts
it's not, unless its a stocker or a generic 350 you get some weight savings a nickel on a Super Stock at least a dime on a Stocker But .005 is a lot we spend a lot of time and money looking for a tenth
Joe Schweigert 751 SS
Joe Schweigert is offline   Reply With Quote
