Is this a stock fuel tank? Not a fuel Cel?
To eliminate a weak (low volume) pump, I would add 5 gallons of fuel. If that stops the pressure drop, it will usually indicate the pump pick up being uncovered due to placement in the tank.
Ed Wright 4156 SS/JA |
Liked 708 Times in 285 Posts
It is a fuel cell with about 10 gallons in it mostly to make weight. Has rear sump and exit with pump directly behind it. Im pretty sure I 45 degree or straight fitted everything. I did install a -8 inline fuel filter when I built car 35 passes ago.
It's the G force causing the problem.
How quick does it ET? And 60’?
Ed Wright 4156 SS/JA Last edited by Ed Wright; 01-21-2020 at 07:13 PM. |
Liked 1,983 Times in 597 Posts
What side of the pump is the filter. I have never ran a filter in my fuel system
Mike Pearson 2485 SS |
Liked 314 Times in 177 Posts
If you are using a fuel filter, check the Microns.
Liked 127 Times in 26 Posts
Jeff did you get a chance to check the volume in a fuel jug for 60 seconds at the front of the car and what volume did you get?
