Old 09-03-2019, 02:12 PM   #1
Mike Graham
Liked 341 Times in 67 Posts
Default Re: Mike Graham/Gary Summers
What I was saying was that both cars that I am associated with have the DA head. That is the head that is listed in the blueprint spec,so by definition , it is the correct head. The takeaway should be to check the blueprint spec before you build a new combination. That is what you will be held to in teardown.
Mike Graham is offline   Reply With Quote
Old 09-03-2019, 03:51 PM   #2
Rich Wallin
Rich Wallin's Avatar
Liked 4 Times in 2 Posts
My take on this the part numbers supplied to nhra need to be updated .... in my experience as an engine design engineer the suffix change usually is production tool related not base design / performance driven
Rich Wallin is offline   Reply With Quote
Old 09-03-2019, 04:17 PM   #3
QuickII
I heard from a reliable source it was for altering the intake casting number, and booster modifications, not the head at all.
QuickII is offline   Reply With Quote
Old 09-03-2019, 04:27 PM   #4
BBF67
Liked 8 Times in 4 Posts
That could explain why an intake and carburator was seen being carried into the tech trailer.
BBF67 is offline   Reply With Quote
Old 09-03-2019, 06:19 PM   #5
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
Talking Re: Mike Graham/Gary Summers
Break out the pop corn. This might get good.
Floyd Staggs 787 SST
Old 09-03-2019, 06:34 PM   #6
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
For everyone's info, the "D-" at the end of a Ford casting number is a revision suffix. DA is the original head. When an engineering change is made to the part the last letter of the suffix is moved down the alphabet. DC heads have had two changes made to them. They may cc the same, but something has been changed. I think that when the suffix was changed, the factory published HP rating stayed the same. NHRA decided they could document the HP of the DA head but not the others and edited the guide to recognize only the DA as legal. Very difficult to build a 1977 Ford 302 stocker.
'77 Chevy 305/145 has three head castings listed
'68 Chevy 327/350 has seven.
I have a Root Beer in the 'fridge...
Dale Shearon
68 Mustang 6394
Old 09-03-2019, 09:34 PM   #7
Liked 5,121 Times in 1,952 Posts
77 is one year only, but shouldn't be hard to find.
So what?
Old 09-04-2019, 03:19 PM   #8
Billy Nees
Liked 7,732 Times in 1,739 Posts
I have been told on numerous occasions by numerous Tech people (including Gracia) that NHRA Tech ONLY checks carb model,throttle bore and venturi size. Period.
If there has been a change in that policy, I'd sure like to know!
Billy Nees 1188 STK, SS
Old 09-04-2019, 05:42 PM   #9
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Billy,
I don't want to get pissy, BUT, so it's OK to polish the secondary bores on a Q-Jet, grind off all of the casting flash, remove he choke plate and machine off the choke horn????
CARBURETOR
Must be correct year, make, and model specified for car’s engine;
fuel or air bleed passages may be resized. Drilling idle holes in
primary
throttle blades permitted. Other modifications prohibited.
Sandblasting, grinding, flash removal, dry film coating, or any
other modification to carburetors prohibited. Replacement
carburetors permitted provided they are same model, type,
throttle bore, and venturi size. Computer carburetors use latest
model non-computer carb for engine application.
Doesn't look like it to me, but on the other hand...….
WTF do I know????
Bob Mulry 7516 STK
A & M Motorsports
Old 09-04-2019, 07:29 PM   #10
Hacksaw
Liked 310 Times in 174 Posts
You may be correct, but don't you think an official should drop the hammer if he sees a funky casting number mod? Of course. They are looking, maybe not checking.
