Old 04-12-2019, 02:56 PM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default Re: Radiator under constant pressure?
I had that issue and it was electrolysis. Put an ohm meter in the water and see how many volts you have.
Old 04-16-2019, 06:22 PM   #2
1legjerry
Liked 72 Times in 15 Posts
This is correct. Make sure your radiator is grounded to the chassis. You could also have a issue with a chemical reaction with any additive you may be running in your coolant. I would do a complete flush and add only water.
1legjerry is offline   Reply With Quote
Old 04-16-2019, 08:04 PM   #3
Jeff Stout
Liked 708 Times in 285 Posts
Im finishing on healing from surgery. When I can I will check electrolysis in radiator. I know radiator is held in place with rubber and plastic. No metal to metal contact. Currently straight water. I will also vacuum down water system to remove any air in system. I have 2 engine shops stating air locked
Old 04-16-2019, 11:40 PM   #4
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Jeff - I would think that if you had air trapped in the cooling system you would experience a problem with overheating, which doesn't seem to be the case. Is this a "new" issue you're experiencing or has this been going on for a while? The reason I ask is because if the cooling system is working properly, there is no reason why the pressure shouldn't remain (it's a sealed system) and usually when the pressure drops it's because of a leak somewhere. The pressure is regulated by the rating on the cap, so anything above that number goes to the overflow tank. If you have a Stant (or similar) radiator tester they have a way to check the cap as well.
Hope the healing process goes quickly.
Lew
Lew Silverman #2070
"The Wagon Master" N/SA
Old 04-17-2019, 07:06 AM   #5
Kirk Morgan
Liked 81 Times in 45 Posts
If your cooling system is working properly the system will go from positive pressure to negative pressure as the coolant expands and contracts from temperature. Your problem could be as simple as a defective radiator cap or the wrong radiator cap. If you have the factory by pass hose i cannot see how you would get a air lock.
Kirk Morgan is offline   Reply With Quote
Old 04-17-2019, 11:12 AM   #6
Jeff Stout
Surgery consisted of a tube installed in my stomach to get ready for dialysis. Stomach muscles are still sore so I can't look at car yet. I will check radiator cap pressure and swap out with a lever type. The car is new build and has had pressure since day1. Ruling out the easy stuff first. Cap, electrolysis, hose and over flow tank, vacuum system down, retorque head bolts
Old 04-22-2019, 06:30 AM   #7
Herbie Null
Herbie Null's Avatar
Liked 439 Times in 69 Posts
I had this problem once, mine was a aluminum head on steel block with a single layer head gasket. I chased the problem all season, water was not getting in oil or coming out of exhaust so I just left the pressure lever up on the radiator cap. When the engine was torn down the head had warped some, resurfaced head and used Cometic MLS gasket and never had anymore issues. I do believe the MLS gasket would have fixed it. I dont know if you have aluminum head are not, just passing along what I came across.
Herbie Null 201 SS
Herbie Null is offline   Reply With Quote
