#21 |
Liked 53 Times in 38 Posts
Quite a difference between 1/2 & 5/8,
Proof load for grade 2-5-8 for 1/2 stud = 8800-13600-19200 For 5/8 stud = 14100-21800-30700, a good 30% + - stronger across the board I always heard not to use the grade 8 because it's to hard & brittle, use grade 5. Not sure what they use from Strange or Moser. |
#22 | |
Liked 280 Times in 139 Posts
#23 |
#24 |
Liked 3,230 Times in 982 Posts
My axles were drilled for both 1/2 and 5/8 screw in studs. The axle flange still isn’t the weakest link.
#25 |
Liked 46 Times in 29 Posts
Contact Mark Williams.
They solved my moser problems that moser just could not. Many length 5/8 studs, washers, lugs and associated parts. |
#26 |
Liked 54 Times in 27 Posts
Grade 8 is stronger across the board, including tensile. My Moser axles are tapped for 5/8" x 18 thread bolts, so I just buy long enough bolts. If the wheel hole is much bigger than 5/8", you could get sleeves or find studs with larger unthreaded areas. People who think grade 5 is better, why does ARP make bolts and lug nuts?
#27 |
Something like, the harder it gets the more brittle it becomes.
