Old 07-15-2018, 08:11 PM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 973 Times in 310 Posts
Default Brake problem
Went from no problem holding the car at 3000 rpm on line to pushing thru the beam. Four wheel wilwood disc brakes.Mopar master cylinder( don't know piston diameter).Checked the pressure at each wheel. 1000 lbs coming out of master going to front brakes. 1000 lbs at front wheels. 800 lbs at rear and it will go no higher no matter how much more pressue you build up. I didn't have an adapter to measure pressure coming out going to rears.Couldn't swap lines from front to rear on master (different sizes). 3/16 lines going to fronts and 1/4 going to rears.
Old 07-15-2018, 09:21 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: Brake problem
Refinish the rotors and install new pads !
ss3011 is online now   Reply With Quote
Old 07-16-2018, 06:24 AM   #3
Glenn Briglio
First thing done at track........no difference
Old 07-16-2018, 07:34 AM   #4
nhramnl
Liked 358 Times in 83 Posts
Have somebody watch the car to see if the wheels are turning or sliding. Also, go over everything you've changed recently that might affect the brakes ability to hold the car, including even things like engine and converter changes. Finally, don't hold me to this, but 1000psi (front) and 800psi (rear) doesn't sound like an overabundance of clamping force.
Old 07-16-2018, 07:53 AM   #5
Glenn Briglio
Nothing was changed. Front tires locked, rears are rotating and pushing car.The 1000 psi can go higher. The 800 at rears will not go higher no matter what pressure is coming out of master.
Old 07-16-2018, 08:01 AM   #6
ss3011
ss3011's Avatar
Is it possible to bleed just the rear brakes and recheck the pressure ? Could be an air bubble .
Old 07-16-2018, 09:02 AM   #7
Glenn Briglio
Could be an air bubble but have bled them 5 times. Nothing but a solid stream of fluid.
Old 07-16-2018, 09:36 AM   #8
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Internal master cylinder leak only once the rear circuit gets to that pressure maybe?
K Danner STK 468
kdanner is offline   Reply With Quote
Old 07-16-2018, 12:05 PM   #9
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Brake problem
Maybe internal degradation of any rubber lines you may have? I heard that they can bunch up and cause internal restriction or blockage as they age.
I've had some trouble with holding the car on the line with OEM disc/drums lately and this thread made me realize that the brake "T" assembly on the rear end housing is the only rubber hose I still have in the system. M/C has been changed and all the other lines are solid or braided.
I put a higher priority on the rear brakes because harnessing the torque there will accomplish more than at the front. The best front brakes still only have a pair of skinny front runners trying to hold the car and can easily slide.
LOCOMOTION Racing
Old 07-16-2018, 12:27 PM   #10
Glenn Briglio
I'm changing master cylinder and rubber hoses going to rear brakes first.
