Old 04-08-2018, 04:22 PM   #1
D.Johns
D.Johns's Avatar
Liked 18 Times in 6 Posts
Default Re: Is there any hope of NHRA separating traditional Stocker
Originally Posted by Rory McNeil View Post
Mr. Kershaw, Why do you say the without the "package" cars, the NHRA did not have a way for late models cars to compete in NHRA Stock Eliminator? New, production cars had been racing in stock for many decades, Ford, Chevy & Dodge did have high performance production versions of the Mustang, Camaro & Challanger available to the public for years before the Cobra Jet, COPO & Drag Packs were invented, just like they were in the 60s and early 70s. Why were these production new cars not viable? Factory HP ratings too high maybe? Thats the manufacturers fault, not racers or NHRAs.
He states the reason in his post.
“As the OEM's have improved the efficiency of the engines there are not the same gains to be had as older combinations.”
The new manufacturing process and standards has eliminated 30hp by turning a screw and 60hp by rebuilding a slapped together carburetor and adjusting the cam or machining with better tooling.
Plus with standards with SAE there is less “slide of hand” items to overrate/underrate due to insurance, advertising etc. HP ratings have to repeatable and within a window.
2014 Cobra Jet FS/XX #3345 STK/SS
Like us on http://www.facebook.com/pages/Daniel...25886327426822
D.Johns is offline   Reply With Quote
Old 04-08-2018, 08:18 PM   #2
Rory McNeil
Yeah, I guess the modern HP ratings are why the new " package cars" can have higher comprssion ratios, bigger cams, larger throttle bodys, and less rated HP than the actual cars that the manufacturers sell to the public. (At least until they eventually get factored).
NHRA 6390 STK
M/S 85 Mustang
Old 04-08-2018, 10:10 PM   #3
D.Johns
D.Johns's Avatar
Do not confuse NHRA rating and consumer SAE ratings. The NHRA usually took the original manufacturers ratings at face value on most VIN # cars. Example of say an L88 factory rated at 430hp actually made closer to 560hp. Compared to a 5.0(302) coyote at 425hp actually making 435hp and would take ported heads, cams and intake to make 560-600hp(500rwhp).
Now was the 08-later “package cars” underrated? Absolutely. The 425hp 5.4/2.3TVS was actually 605hp
As far as the Ford side of things a large chunk of the turnkey cars used factory part #s/castings. A huge amount of the parts are on the VIN car if you choose to build one from that and you can go to the Ford dealer to order the remaining parts(even the blower was a dealer installed option that would retain the factory warranty/emissions)
Old 04-08-2018, 10:22 PM   #4
6130
Liked 117 Times in 50 Posts
As I've been away from the sport for a quarter of a century or so, can someone explain to me (in simple terms) the degree of separation that the Factory Showdown provides between regular Stockers and the factory race cars? The YouTube videos I've seen show the factory race cars racing against regular stockers- I don't understand.
Old 04-08-2018, 10:37 PM   #5
D.Johns
D.Johns's Avatar
The Factory Stock Showdown is a heads up class completely separate from Stock eliminator. Only ran st 7 events and only the quick 16 get into the show. Don’t qualify you go home. *Any year (08-present) Factory SC engine in any year (08-present) factory drag car. All other Stk rules apply with min weights set based on engine combo. 2.3/5.4 is 3350 and 2.9/all other engine sizes is 3550#
The “Factory Stock” “paper” cars 08-present have the FS designation in stock and super stock for their class within stk/SS. Normal stk/SS rules apply. Same class is heads up run all else bracket race.
Old 04-08-2018, 11:06 PM   #6
6130
Thank you.
So the supercharged factory race cars can run Stock Eliminator OR the Factory Stock Showdown, but the normally-aspirated variants can only run in Stock Eliminator?
Old 04-08-2018, 11:07 PM   #7
D.Johns
D.Johns's Avatar
Thanks.
Correct...
