Liked 598 Times in 164 Posts
Freshening my 350/287 hp motor and the oil pan that was on it looks like a Milodon with a trap door and baffle on the passenger side. I have a 1965 Corvette oil pan and pickup with windage tray, crank scraper and oil pump plate that sandwiches betwwen the pump and rear main cap. Mellings HV oil pump too. Any recomendations on which pan and wether to use the scraper or windage tray (Corvette original too) and also feelings on the lifter valley shield.
Thanks in advance Rich Boyle |
I would not put that high volume pump in it.
The SBC is the last engine that would need one.
Ed Wright 4156 SS/JA |
Liked 30 Times in 16 Posts
Standard volume high pressure. Mellings make's billet or standard. Make sure to get the correct pickup.
Liked 18 Times in 10 Posts
The Melling 10553 is a good pump STD Volume High Pressure or the 10552 is a 10 % more volume pump which is a pump Ii use a lot of.
I never use a 25 more volume pump. It really depends where all your clearances are !!!! Last edited by carl hinkson; 12-11-2017 at 06:11 PM. |
Liked 205 Times in 93 Posts
a scraper custom fit to the crank is worth the effort. the bigger the pan the better. corvettes pan and its trap door is great. be safe with the amount of oil. lifter valley tray to keep the hot oil off the intake.
Liked 456 Times in 148 Posts
As well, consider working on controlled oil return to the pan.
Steve Teeter STK 6380 |
Liked 22 Times in 22 Posts
Standard stock as a rock oil pump. It's all you need in a sbc.
don,t have one |
Liked 358 Times in 83 Posts
#9 | |
I have run 40 psi for years. I have a rear main cap, tapped for a hose to an oil pressure gauge for testing pressure. I just drop the pump into my parts washer, hooked to an electric drill. What I see there is always what I see in the car. I have one of Allen Sherman Sr's low volume pumps in mine right now.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 12-11-2017 at 02:35 PM. |
