Old 02-20-2017, 12:21 AM   #1
voltdr
Liked 100 Times in 51 Posts
Default Re: What Works and What Doesn't
Want to get the streaks off of your trailer, RV, or motorhome without the alot of elbow grease. "LA's Awesome" cleaner. I get it at Dollar Store. Others have it also. Only $1.00 a bottle. Spray on wipe off.
Dan
voltdr is offline   Reply With Quote
Old 02-20-2017, 12:11 PM   #2
Liked 5,114 Times in 1,948 Posts
Dollar Tree's version of CLR will clean rust and crud off of bolts and hardware. Let them soak for a day or two.
They don't have it all the time, so if you see some , grab about a half a dozen bottles.
If not , Zep's version is cheaper than CLR..Get it at the sticks and bricks store.
Old 02-22-2017, 10:03 PM   #3
S/ST J718
Looks like everyone has a favorite , been in the Harley world now for 27 years so I have tried a lot of great polishes . But the best I have found at is available at Walmart , its called Cape Cod Polishing clothes . American made and this will leave a protective coating resisting future tarnish . here's a link https://www.walmart.com/ip/Cape-Cod-...-Each/23500565
Old Nick in Tucson! Hahaha
S/ST J718 is offline   Reply With Quote
Old 02-23-2017, 10:52 PM   #4
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Dan
I've used this it really works.
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 02-24-2017, 10:46 AM   #5
Rsmith38
Liked 28 Times in 15 Posts
I have also used the Awesome orange from dollar Stores - works well.
They also have a refill bottle (clear plastic, yellow liquid) for $1 which makes 3 to 5 refills - for a couple of bucks you can do a trailer! Stuff also cleans under hood on used cars, Spray on - let sit, Hose off!
Rsmith38 is offline   Reply With Quote
Old 02-24-2017, 01:07 PM   #6
Ed Wright
Ed Wright's Avatar
Good stuff!
Ed Wright 4156 SS/JA
Old 01-19-2018, 09:17 AM   #7
Liked 10,683 Times in 2,223 Posts
Working on the Drag Pack that has a S 60 Dana housing. Is it neat or what, it has screw adjusters to set the back lash and carrier bearing preload . No more spreading the case and adjusting the carrier with shim packs.
What doesn't work is calling the tech line and receiving incorrect information. I did some further looking on their web sight and found the correct procedure to set preload. I'm real happy I double checked, it saved me a bad day at the races, money for parts, and a lot of work.
Its a good product, I think.
Old 01-19-2018, 10:51 AM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 859 Times in 234 Posts
I'm all for clean and shiny cars ,but over the Winter a lot of racers forget about one of the most important things ,other than a win light , Brakes !
Take some time to inspect the hoses. ... if they are more than five years old replace them ,they are cheap insurance.
Flush out the old brake fluid and replace it with quality racing brake fluid like Wilwood's 570 Plus ,or other high quality DOT 4 fluid.
Brake fluid is hygroscopic ,it absorbs moisture and over time becomes corrosive to your steel and aluminum brake components .
We all want to keep the shiny side up !
Old 01-19-2018, 01:37 PM   #9
Jeff Niceswanger
Liked 1,019 Times in 367 Posts
I always had issues with rear end seepage after a few months of racing . The bolts, even though they are self locking with Loctite always pounded out the gasket and leaked .. This gasket ends all that. It's a steel shim with reusable gasket material on both sides... and their cheap ..
Lube Locker Ford 9" Differential Gasket
https://www.amazon.com/Lube-Locker-F...ds=Lube+locker
Jeff Niceswanger 3740 SS
Old 01-19-2018, 04:59 PM   #10
Eman
Liked 133 Times in 76 Posts
Never wasted my time with a gasket on a 9". A tube of Ultra Black RTV and self locking nuts on the studs works for me. I used copper washers under the nuts.
