Old 01-02-2017, 07:21 PM   #21
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: LT 1 350 valve to piston clearance
Curious. Why more Clearance on the Intake vs Exhaust. ?
Should be more clearance on the exhaust than on the intake. Observe the relationship of the valve action in comparison to the rotation of the engine during the cycle. The piston is closest to the intake valve as the piston is approaching TDC and the valve is closing, so any contact will "push" the valve closed and/or the clearance will increase rapidly. For the exhaust valve action, the opposite is true. The piston is closest to the exhaust valve as the piston is approaching TDC and the valve is opening. The camshaft will push the valve into the piston and potential damage is greater.
There are other factors like what causes valve float, etc., but the above is generally true.
Old 01-02-2017, 08:17 PM   #22
Ed Wright
Ed Wright's Avatar
Originally Posted by rawhide View Post
Dan,
The exhaust valve runs much hotter than the intake and expands more.
Roland
The exhaust valve and the piston are moving toward each other at the closest point.
Intake Side, the piston and valve are moving the same direction. You can run them closer.
Ed Wright 4156 SS/JA
Old 01-02-2017, 08:39 PM   #23
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The piston is chasing the exhaust as it's closing, if it's a little tardy it gets smacked. The intake is chasing the piston as it's heading down, if the valvetrain is tight you can run .010" on the intake and it'll never hit.
Old 01-02-2017, 10:16 PM   #24
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Come on guys you all know the answer.............
Exhaust valve is closing and being chased by the piston and depends on valve spring pressure to stay ahead or be bent.......
Intake valve is opening and chases the piston down the hole and is controlled by the cam profile.....
Bob Mulry 7516 STK
A & M Motorsports
Old 01-03-2017, 12:11 AM   #25
randy wilson
Liked 22 Times in 22 Posts
I agree with this. I've ran em so tight that at zero lash on the intake, the motor would not turn over by hand. Set the valves, and turn 10,000 with no problems. The exhaust, high 70's is as close as I've ever dared. And you'd better have good springs.
don,t have one
