#1 | |
Liked 783 Times in 195 Posts
Liked 335 Times in 182 Posts
I had some aluminum cast adapters made up for sale. They are only about 1/2-3/4 inch in thickness that will allow a 4GC carb which has a 4 7/32 in diameter opening to use a pan with a 5 1/8 inch diameter opening which is what most Holley/Quadra Jet carbs are. I have both a shallow dropped base air pan and the adapter which will fit many applications where hood clearance needs to be considered--- contact me for more pics/info---FED387
Liked 24 Times in 13 Posts
Danny, does the Speedway Motors carb base pass the "stright edge" test?
Terry K |
Liked 110 Times in 29 Posts
Terry:
Yes it does. I just check it with a Chevy and a Pontiac Q-Jet and the straight edge is dead even with the top of the choke housing. Should be good to go. |
Thanks Danny. Speedway Motors site say it "fits Holley carbs".
Terry K |
Terry:
Yes it does but Holley and Quadrajets both use a 5 1/8 air cleaner. The only thing to watch when using one on a Q-Jet, sometimes it requires a slight modification because the accelerator pump lever may hit. Also when used on a Pontiac carb, a hole needs to be drilled for the front vent tube. Easy fix for both. |
Thanks Danny for the great info,as always.
By the way, my carb is working as good now as the day I got it back from you. Terry Knapper |
