Liked 223 Times in 73 Posts
Ok so you have all your info to give to a torque converter manufacturer to have one built. What is there science or theory of the build for stall, flash and engine to drive shaft ratio at the finish line? Is the flash your peak torque? then how about shift points and finish line rpm a couple hundred above your peak HP? Is it harder to build with a wider range in between the torque and HP. Not looking for the mechanical build like fin angles and size just the science behind it.
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 Last edited by west coast; 07-04-2015 at 12:40 PM. |
Liked 7,936 Times in 1,518 Posts
Lots of experience and a nice pair of pliers will get you a long way in the converter business. Am I correct YAK ?.......M.J.
Have a dyno sheet handy, if you have one, when you call to order one.
Ed Wright 4156 SS/JA |
#4 | |
Liked 5,120 Times in 1,951 Posts
I was hoping I could stay out of this for now, only because it's going to take about a two hour dissertation to answer all of James's questions. I was hoping Ultimate Lenny had some time to spend with us ;-). Let me say this for now. There are formulas and tables for phantom engines that can used as a guideline, but seeing most S/SS engines don't match up very well, the builder is still going by feel and experience most of the time. Most of you have had a new ,latest trick of the week engine that won't go down the track as fast as you're old basic standby. Then you can imagine what a converter builder has to go through with that same combo.
Liked 216 Times in 77 Posts
Wasn't looking for a 2 hour seminar or give anybody carpal tunnel from typing. Just basics I know there is a big difference between stock/SS, comp style stuff then the super classes and top sportsmen stuff but there seems to be some interesting stuff going on with the top sportsmen like lock up converters. Back to the subject so there is colored charts and graphs they work off as a base line then experience from there takes over. In a performance class like us getting the car to 60ft is key, specially with the weight of some of these cars. So with the dyno sheet ( and all other info like weight and gear ratio of rear end and tranny's first gear, cam, head, intake) in hands of the converter company where are they shooting too for the flash of the converter to happen at peak torque or some percentage above or below it?
James Boyce 6052 K/SA Stock National record holder 2015,2018,2 times in 2022,2023 |
That's insider information, James. j/k
Actually the charts and graphs I've seen have to do with the GM 245 mm core, which is a step larger than the old Opel standby. There are about 8 different factory impellers (fin angles) plus 4 or 5 stators, so it's kind of a mix and match deal there. Not so much with the Opel 8". There's really only a couple of stator designs, so they have to be machined to fine tune the combination. The fin angle starts out basically straight ahead or neutral, so it has to be adjusted within it's workable window. There are a few more subtle tuning tricks but you're always walking a fine line there. Seeing a torque converter multiplies torque, it stands to reason you would want to multiply as much as you can. Sometimes that flash point wants to be a little over peak, at it, or a little under, but yes, right around it it. No dyno sheet , but with a popular combo? Usually no problem, with a large enough data base. Odd ball or Dime Rocket type combos? That's where a lot of S/SS racing experience helps, but also a s.w.a.g. sometimes. Gotta give the carpel a rest, but specific questions?
Liked 237 Times in 126 Posts
Just to fill in a bit, we're talk'in 5.0L aka 302 EFI Ford spinning a C4 in a Fox Mustang. K-L/SA. Converters should be generic on a conceptual level, which is what Jim is after here, but sometimes it helps to know the combo.
Jim: Performance Automatic has a downloadable torque converter order sheet that might give you an idea of the info needed to put one together for a given engine combo. I have their foreword shift servo and it's first rate. Dale
Liked 244 Times in 26 Posts
Mark,
Are there any general converter fundamental governing equations? Folks always talk about flash rpm and lock-up, but what happens to torque multiplication when flash rpm is "adjusted"? Also, what happens if fluid viscosity changes? |
Chris ,There are some formulas but they are very complex.I certainly can't understand them but you just might.
I found something that might be easier to comprehend for most here: http://www.sonnax.com/articles/90-Hi...ction-and-More On the second part, the best non answer I can give is it might get better or it might get worse. Generally when you soften one up by machining stators away from factory engineered profiles, you do lose a few % points of torque multiplication . But if it gets you up where there is more torque to multiply at a certain rpm, then you still will have a net gain in ET. Personally,I haven't seen any big swing in brake stall within what one would call normal drag racing temperature ranges. Once we get to the point where the fluid starts to boil and vaporize, then we will see a loss in 60' times for sure. I'm assuming you were asking about temperatures, seeing that most folks use one form of 10w ATF or another. If you're asking about synthenics in converters, I have no experience. Some else will have to field that one.
