Old 06-26-2015, 09:16 AM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: Roll cage door bar and window crank
A "contoured" bar is not as strong as a straight bar.
Depends on the hit. Bars that are contoured out are stronger in a side impact. Anyway, considering all the structure of a cage, there is a lot more if the structure that comes into play in a crash than just that side bar.
Old 06-26-2015, 09:27 AM   #2
grncpe
Liked 44 Times in 10 Posts
I have a 70 Cuda also with s&w cage, I altered the door bar to be able to use the stock handle with the window net up. You can still wind the window down & up but it's a pita. Easier to have the door open. I can post some pics if you like?
Tommy Baker SS/GA # 172
E/SA # 1272
grncpe is offline   Reply With Quote
Old 06-26-2015, 10:15 AM   #3
GallopinGhost
GallopinGhost's Avatar
Liked 21 Times in 13 Posts
Yeah, a picture from the inside showing how it routes by the handles would be great. I have a challenger, not sure if the handles are in the same location or not.
Brian Carpenter
Stock 1358
GallopinGhost is offline   Reply With Quote
Old 06-26-2015, 03:07 PM   #4
buzzinhalfdozen
Liked 11 Times in 8 Posts
SFI specs allow bends in door bars, at least on a 8.50 car...not sure on the lower E.T. cars but doubt it. My personal opinion on swing out bars is not a big fan. Just looking at them in different variations not sure I'd ever put one in my personal car. I see no way ity could be as secure as a PROPERLY welded bar. BTW dale I've used a couple of the cheap, lite cable operated power window set ups from the newer cars on cars not designed for the...works great, however there is a little fab work involved. Can be done for less than 150.00 both doors less wiring and switches.
Joe Buchanan SS/BX 3117
Old 06-26-2015, 06:09 PM   #5
Jim Caughlin
Liked 805 Times in 245 Posts
Ask Jeff Lane about power windows, a few years ago he had one fail in the down position (and if I remember right it was in eliminations, not qualifying), got booted and lost the round. I guess I'm a big fan of simple mechanical things that are less likely to fail. Also wonder how happy they are with 16 volt batteries.
Jim Caughlin is online now   Reply With Quote
Old 06-26-2015, 06:38 PM   #6
Ed Wright
Ed Wright's Avatar
Mine have been fine with 16 volts for almost 6 years now. Faster.
Ed Wright 4156 SS/JA
Old 06-26-2015, 06:41 PM   #7
Ed Wright
Ed Wright's Avatar
But, not curved down to clear window cranks. No room to curve one out in anything I have raced. Had to notch the arm rests to shut the door on straight bars.
Old 06-26-2015, 06:44 PM   #8
Jason
Liked 8 Times in 5 Posts
At least this way you cannot roll the window down until you turn off the end of the track.
Jason is offline   Reply With Quote
