Old 11-26-2014, 06:24 PM   #2
SSDiv6
Default Re: Oil pan and timing cover gaskets
Originally Posted by Marvin Robinson View Post
I'm almost done with my new Olds 455 engine, any recommendations for oil pan and front timing cover gaskets? (Cork vs rubber) Should I use gaskets on both sides or the pan scraper, one side with Ultra Grey on the other, or just a lot of Ultra Grey on both sides? .
Use the Olds 350 Diesel oil pan gasket which has a metal core between the scraper and oil pan. Then use Ultra Grey between the block and the scraper/oil pan. Also use Ultra Grey on the timing cover.
