Old 06-18-2014, 11:28 AM   #31
Ed Wright
Ed Wright's Avatar
Default Re: Steel rod life expectancy
That break was caused by the spun bearing.
Ed Wright 4156 SS/JA
Old 06-18-2014, 11:42 AM   #32
joespanova
Liked 13 Times in 11 Posts
Well , in the end , I blame myself for be stupid enough to A) continue to run it when I KNEW the rods had been in there for a while and B ) being too lazy to tear it down over the winter where I may have seen a problem.....but , like I said I'm a slow learner
Old 06-18-2014, 12:12 PM   #33
Glenn Briglio
Glenn Briglio's Avatar
Liked 986 Times in 314 Posts
Bearings don't usually fail by themselves. The connecting rod dimensions change or oil supply changes.
Old 06-18-2014, 12:16 PM   #34
Ed Wright
Ed Wright's Avatar
Or clearances were wrong to begin with.
Old 06-18-2014, 12:40 PM   #35
joespanova
Not in this case. I'm a machinist for a major airline for 26 years.........and years prior to that. I have and have access to , every conceivable bore gauge and mic's anyone would need.
I assemble and check them........no chance in hell they were wrong.
Generally .0025-.003 at the vertical. Or whatever the rod manufacturer suggests.
I just ran it too long without an exam or freshening.
Old 06-18-2014, 12:42 PM   #36
joespanova
Originally Posted by Glenn Briglio View Post
The connecting rod dimensions change .
I suspect this was the case.............
Old 06-18-2014, 02:30 PM   #37
Ed Wright
Ed Wright's Avatar
SBC? Why so much clearance? You do know that aluminium rod will expand much faster than the steel crank, right? Imagine how loose they are at operating temps. I don't run my steel rods that loose.
Old 06-18-2014, 02:41 PM   #38
Dion Hildebrandt
Dion Hildebrandt's Avatar
Mine was instigated by detonation
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
Old 06-18-2014, 06:37 PM   #39
joespanova
Well , I don't know what to tell ya........engine builders a lot smarter than me have run em that way for years........if I ran em tighter and it failed I'd be blaming it on that.........
Old 06-18-2014, 08:29 PM   #40
Ed Wright
Ed Wright's Avatar
Yep. Hammering the bearings causes the ends to pull in & squeegee oil off the crank. Too much clearance often has the same effect, just takes longer.
