Old 06-04-2014, 02:37 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: 60 ft varies and no wheel speed in burnout
Dave, if I recall correctly your 200 has a pressed in steel stator support. They don't break but will occasionally spin out the serrations. Put a big set of water pump pliers on it and make sure it won't turn. If you need a convertor quick, call Grant Eldridge, I think he still has one for sale.
Jim Mantle
jmantle is offline   Reply With Quote
Old 06-04-2014, 03:23 PM   #2
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Production 200/200-C have a one piece casting for the pump cover and stator shaft. Is there an aftermarket company that makes a pump cover with a pressed in stator shaft ?
Old 06-04-2014, 03:29 PM   #3
Dave Jung
Dave Jung's Avatar
Liked 5 Times in 5 Posts
Thank you for the responses guys. Looks like I will pull the tranny this weekend. I won't feel good until I at least have a look.
Steve, I will call tonight after work. Thanks
6535 stk
81 Malibu K/SA
Dave Jung is offline   Reply With Quote
Old 06-04-2014, 10:45 PM   #4
jmantle
I make up my own shafts and machine out the pump cover to install it.
Jim Mantle V/SA 6632
Old 06-04-2014, 11:23 PM   #5
Dave Jung
Dave Jung's Avatar
I should also let you guys know I changed from C12 to Sunoco purple without any jetting or tuning. Maybe I have messed up my tune?
Thanks again
6535 stk
81 Malibu K/SA
Old 06-05-2014, 07:26 PM   #6
Bill Edgeworth
Jim,
I'm curious, that sounds like a fair amount of work why not just convert to a 350 front? Is it not stronger? Or is that a lot more work than making the shaft?
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
