Old 04-21-2014, 10:20 AM   #1
Johnny Rod
Default Cranks ?
Who sells a replacement crank for super stock. 327ci . I read it on here but can not find it.
Johnny Rod is offline   Reply With Quote
Old 04-21-2014, 11:08 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Cranks ?
The rules say OEM or Accepted aftermarket crank only. Problem is, NHRA lists no aftermarket crank for the 327 Chevy. I'm a ford guy. so that's an assumption.
Technically, there are no aftermarket cranks for any Super Stocks as the list reads Stock Eliminator Aftermarket Cranks. For rods it separates Stock and Super Stock.
The list is a bit of a joke. The only listed crank for my 302 Ford is an Eagle part that hasn't been made in 9 years. Eagle has submitted the replacement for approval several times but nothing happens. I just went with a forged crank that matched stock weight and specs. I'll plead dumb if they say anything.
Dale
Dale Shearon
68 Mustang 6394
Old 04-21-2014, 11:31 AM   #3
Rat Raceway
Rat Raceway's Avatar
Liked 35 Times in 17 Posts
Send a message via MSN to Rat Raceway
Dale
Its a little work but nothing crazy to get a crank approved. I got one approved for this year.
Fill this out add pictures and you should be there as long as all spec's are correct.
http://www.nhra.com/userfiles/file/A...val%20Form.pdf
Info
http://www.nhra.com/userfiles/file/N...%20Process.pdf
Ross Gregory
5133 Stock,Super Stock
53 Top Dragster
Rat Raceway is offline   Reply With Quote
Old 04-21-2014, 11:34 AM   #4
Johnny Rod
Thanks Dale, I called Callies they said they have a steel one that's on the list. $$$$$ ouch!
Old 04-21-2014, 11:37 AM   #5
FireSale
FireSale's Avatar
Info
Thanks. I saw that form and thought it was corporate, not personal. I get my crank back from the balancer today or tomorrow and I'll take photos to submit.
Thanks again.
Dale
Dale Shearon
68 Mustang 6394
Old 04-21-2014, 11:40 AM   #6
Chad Rhodes
give me the part number and I can probably beat the price
Chad Rhodes 2113 I/SA
Old 04-21-2014, 06:54 PM   #7
Liked 1,940 Times in 437 Posts
In Super Stock, the rules stated it could not be billet (the forging line had to be visible, at least on the flange), and the counterweights could not be knife edged. They may have changed when aftermarket crankshafts were allowed in Stock.
You'll be hard pressed to find a small journal 3.25" stroke crank for anything close to a reasonable price.
Old 04-22-2014, 08:42 AM   #8
Johnny Rod
Chad you have a PM. Your right Alan just have to save up and take my time.
Old 04-22-2014, 09:23 AM   #9
nhramnl
Liked 358 Times in 83 Posts
I have a standard/standard, small journal, 3.25 steel crank that I would be willing to sell. If you're interested, send your phone number and I'll call you.
