Old 04-17-2014, 02:37 PM   #1
njk53
Default Re: 65 Plymouth wagon
If my memory serves me correct the 4bbl Hi-Po motor only came in the Dart and Barracuda and I think it was a 10.25:1 motor w/solid cam.
The 273 CI wagon only came with a 2bbl Carter Ball&Ball carburetor. Not sure if a 4 speed was available.
I am pretty sure you are going to have to run 8.5:1 CR pistons in your combo. However, a 65 Plymouth Wagon would be a cool piece.
Did the wagon come with a 361 or a 383 in 65? I would check out the big block combo because I think they were available with a 4bbl.
Nelson Kowal
Stock 345
Old 04-18-2014, 09:14 AM   #2
65wagon
I looked up Bill Koski 's car it's a 66 273 2 barrel with a 4 speed so I Think I can run a 4 speed because I think it was an option in my year not sure who I would check wit to be sure!
65wagon is offline   Reply With Quote
Old 04-18-2014, 09:22 AM   #3
ss wannabee
Liked 7 Times in 7 Posts
Didn't some of those 273's come with a Stromberg 2bbl?
ss wannabee is offline   Reply With Quote
Old 04-18-2014, 09:22 AM   #4
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Here you go... http://www.oldride.com/library/1965_...belvedere.html
Rich Taylor
I/SA - 321
Old 04-18-2014, 09:30 AM   #5
65wagon
Yes i believe they did have a stromburg and on that link it says the 4 speed was an option on all belvedere and satellite models.
Old 04-18-2014, 11:27 AM   #6
James L Miller
Liked 25 Times in 16 Posts
A friend of mine used to run a 1965 Plymouth Valiant with the 273. I remember him telling me the 1965 273 had a bigger carb. From the specs from NHRA, it looks like the Stromberg has a slightly larger venturi than the Carter BBD.
180 273 DP 8.8 1-2 B&B BBD-3843S/SM 3844S/AUTO 2463252 1.5 M 57.3 B,5
Carter Carb sizes – 1437/1063
Strom Carb sizes – 1437/1125
It also looks like the 318s got a bigger carb. I never knew they were different.
Mopar 2 Ya!
Old 04-18-2014, 11:51 AM   #7
65wagon
Awesome thank everybody for the info i am really excited about building this car i have a lot of the parts already just need to figure out what manual trans i can run for sure then i can get started building
Old 04-21-2014, 06:35 PM   #8
magnumv8
The 4 speed is no problem it is legal....160 hp rated stock heads,
167 hp rated with Edelbrock 60767 replacement heads....with the 2 bbl carb, small bore and valves hard to say if the 60767 heads would be worth the cost.....also the Stromberg carb is a legal replacement
D L Rambo....STK 1300
magnumv8 is offline   Reply With Quote
Old 04-21-2014, 06:50 PM   #9
John Lang
Liked 6 Times in 2 Posts
With all of the Killer cars in U/SA, and there is a bunch, I would give some strong thought about going with a 361 w/2bbl,or a 383 w/4bbl AFB ! Or even a 426 Wedge w/4bbl AFB ! The parts are available anywhere, and cheap ! No 4sp in Wagons in 65 ! I think ! ..John
John Lang 365 STK, SS
John Lang is offline   Reply With Quote
Old 04-18-2014, 12:15 PM   #10
Rory McNeil
You could also get the 235HP 4 barrel 273 in a 65 Plymouth Valiant. I owned a 65 Valiant Signet 2 door hardtop with a 273/235HP 4 speed while I was in Grade 12 in high school. The weak links were the small diameter clutch, and small rearend, which I understand the 66 version had a 8 3/4 diff, but I think all the 273s used a small clutch. Of course that could all be upgraded. Angela Bushmaker races a 65 Valiant 235HP in K/SA here in Div.6, and it runs really well.
NHRA 6390 STK
M/S 85 Mustang
