Old 03-08-2014, 11:08 AM   #31
Liked 5,121 Times in 1,952 Posts
Default Re: Metric 200 Trans
Originally Posted by impstocker View Post
Could I use a 200 in my BBC 396/325 65 Impala I am building? Weight would be 3800-4100 lb car. I have a TH 350 I plan on putting in the car- just wondering?
Will Lamprecht 65 Impala I/SA in progress
I can give you a definite answer on that....
Maybe!
Old 03-10-2014, 05:40 PM   #32
Mike Jones
Liked 684 Times in 289 Posts
A friend put one behind a 455 Buick GS Stocker
Lasted about 10 passes, before it grenaded in the lights
Old 03-10-2014, 06:14 PM   #33
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
That car was 3700 lbs. I was in other lane, got a flat rear tire in the lights. Not fun.
Bob Bender 144 O/SA
Old 03-10-2014, 07:38 PM   #34
Mike Jones
I forgot that part of the story, Mr Bender
How are you sir?
Old 03-10-2014, 08:35 PM   #35
Dave Ribeiro
Liked 56 Times in 27 Posts
Wink Re: Metric 200 Trans
It all depends on Who builds it, I have had no- problems with Sepanek for over 12 years.. My car weights 3850 # , did have a crack housing once & that's the weakest link with those old housing ? Yes, the brace helps but if you lose a rear-end . First thing to check is Trans housing & tranny gears,
sprags ...
Good luck, go with a good tranny guy and be done with it.. Metric -200 is the way to go, do the math ? If you buy a T-350 or glide you still have to buy a lower first gear ??? The Metic 200 comes with a 275 first gear, you just saved $500 , so $1000-1200 doesn't look bad at all .... Also , 50-60 lbs lighter , what's not to like ??? Way more racer are using them and not saying anything, what does that tell you !!!!
Dave Ribeiro 1033 STK
Old 03-11-2014, 01:11 AM   #36
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Thomas Arnett runs one of his 200's in his big block '69 Camaro Stocker...best pass so far is a 9.89 I believe.
Rich Taylor
I/SA - 321
Old 03-11-2014, 10:16 AM   #37
Lyn Smith
Liked 973 Times in 195 Posts
IF you are going to run a metric in a heavier car,(3600lbs.and up) i would spend the extra $300. or so and get the good bellhousing put on it from the start.
Old 03-11-2014, 06:09 PM   #38
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
What manufacturer makes bellhousings for the 200 ? Can you get one for a BOP case ?
Old 03-11-2014, 06:15 PM   #39
jim powers
jim powers's Avatar
Liked 13 Times in 10 Posts
i believe the jw bell has both patterns
jim powers is offline   Reply With Quote
Old 03-11-2014, 06:59 PM   #40
stocker4046
purchased two J W Bell's about $330
stocker4046 is offline   Reply With Quote
