Old 12-21-2013, 01:27 PM   #11
Default Re: Wheel shimmy
Originally Posted by Kenney Kelley View Post
Where do you buy longer ball joints ? Would they work on a 66-67 Chevy ll ?
Thank You Kenney Kelley
Long uppers would raise the front end height on a 1st gen. Chevy II, ...which you don't want.
Old 12-21-2013, 02:18 PM   #12
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Originally Posted by Alan Roehrich View Post
Kenney, you need Eddie Rezac's stuff for the Chevy II, if you don't have it already. Not sure if there are long upper ball joints for the Chevy II like there are for F and A body cars, the early Chevy II is vastly different from everything else.
Alan you are spot on when you say the early Nova front ends are different. The 68 and beyond are the same as a Camaro and that may give more options.
Eddies66 is offline   Reply With Quote
Old 12-21-2013, 02:40 PM   #13
It seems to me that GM just copied Ford's better idea 60 Falcon
Old 12-21-2013, 03:04 PM   #14
Kenney Kelley
Liked 72 Times in 36 Posts
Thanks to everyone who took time to answer my questions . I didn't mean to take over the thread.
Kenney Kelley is offline   Reply With Quote
Old 12-21-2013, 05:49 PM   #15
Eddie Rezac
Liked 63 Times in 7 Posts
Smile Re: Wheel shimmy
If you have an early Chevy II, my kit will keep the toe exactly as you set it, all through its travel. Call me at, 402 443 8424 If I happen to not answer, please leave a message.
Eddie Rezac
Eddie Rezac is offline   Reply With Quote
Old 12-22-2013, 10:34 AM   #16
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Thanks for the replies. This still shot does show camber woes.
[IMG][/IMG]
Here's a short video that only shows the right side of the car. At about 25 seconds it goes slo mo and shows what's happening to the right side. I can't feel it when driving. I appreciate your thoughts.
[ame="http://www.youtube.com/watch?v=I3GIj3xdbnk"]Nova burnout and wheel stand at 75 and 80 dragway - YouTube[/ame]
Ron Gusack is offline   Reply With Quote
Old 12-22-2013, 01:02 PM   #17
Greg Hill
Liked 279 Times in 68 Posts
We tried everything on my son Andrew's car and ended up having to put a steering damper on it. My car is just like his except he has wheelie bars and I don't. My car doesn't shimmy like his did. Both are 70-71 Camaros. The steering damper cured his car.
Greg Hill 4171 STK
Old 12-22-2013, 06:52 PM   #18
Eddie Rezac
Have you guys checked that the steering box is set on center. When a box is off center the steering wheel will have an excess amount of play, and can cause a very severe shimmy. When it is dead on center, there is a high spot, in the box where it has "0" play. This applies to all vehicles, (street, race or otherwise) except those with rack and pinion steering.
A Chevy II of the 1968 and later can benefit from longer upper ball joints. The kit that I build is for the 1967, and older Chevy II. It is a completely bolt on kit, no bending, or modifying anything else, just follow my instruction sheet, and go racing.
Eddie Rezac 402 443 8424
Old 12-23-2013, 08:36 PM   #19
Ron Gusack
Ron Gusack's Avatar
The Global West control arms have standard BJ's. Is that because they're built in such a way that long ones aren't needed?
Old 12-24-2013, 09:06 AM   #20
Liked 1,836 Times in 417 Posts
I don't think so. All you need are the Glodal West bushings and the 1-1/2" longer upper ball joints in stock A arms.
