Liked 84 Times in 21 Posts
Looking for suggestions of what to use as an inline filter with race jugs and flexible hose. Or what are you using as a filter from jug to cell?
Liked 38 Times in 17 Posts
Liked 1,877 Times in 577 Posts
i took some aluminum screen and put two layers crossed over the nipple then put the hose back on.(the nipple and hose screw onto the cap) I believe some come that way when u buy them
Liked 6 Times in 2 Posts
Doug
I have been using a paint strainer in a funnel when filling the cell for over 20 years and have not had an issue with debris. When I was unfortunate enough to run a BG fuel pump, the strainer showed the fiber outer pump liner disintegrating before it could cause problems in the lines or carb.
Mike Semeniuk 632 GTMA |
I hear you Mike. I've been using the same thing in the past and am looking to ditch the funnel thing altogether. I'd like to pour from jug to cell with the hose on jug cap but would like some kinda inline filter too. Just trying to get some ideas from what others may have used. Doug
#6 | |
Liked 1,937 Times in 582 Posts
Mike Pearson 2485 SS |
Liked 333 Times in 180 Posts
paint filters work but you can get "fuzz" from the paper ones that might clog up passages etc.--- unless you can get the ones that have the plastic filter media in them--FED387
#8 | |
As far as a inline filter on your actual jug hose goes, I don't know of anyone making one like that, but it would be nice. You might could rig up one if you could put a AN10 fitting on the jug hose and then attach one of these inline filters to it. Last edited by jim hensley; 09-27-2013 at 08:42 PM. |
