Old 05-05-2013, 10:04 AM   #1
Todd Hoven
Guest
Posts: n/a
Default Nitrided Comp cam
Has anybody had any issues with running a Nitrided Comp cam with Smith lifters? Does Comp still do this process with non roller cams?
Old 05-05-2013, 11:37 AM   #2
Default Re: Nitrided Comp cam
I use that process on our own flat tappet cams with Shubeck lifters, and sell them to people using Smith's lifters, it works well.
Yes, it is offered on cast core flat tappet cams, I don't buy or sell one without it.
Old 05-05-2013, 11:47 AM   #3
Adger Smith
Liked 880 Times in 311 Posts
After having some failures on FT cams used in limited C Track engines I switched to the Comp Nitrided cams. Now I don't sell any thing but them. Finally started getting some of the small diameter springs with good rates to handle the RPM. Then the cams are too soft and fail. Seems like you are always chasing you tail in this business. Do it and don't look back. Look forward to the next thing that will fail, like fuel pump pushrods.....
Adger Smith (Former SS)
Old 05-05-2013, 03:28 PM   #4
carl hinkson
Liked 18 Times in 10 Posts
I have used P-55 cam cores with no problems with my C track engines actually with all my HYD and flat tapper engines street and strip.
carl hinkson is offline   Reply With Quote
Old 05-06-2013, 12:22 PM   #5
69Cobra
Liked 2 Times in 2 Posts
Ok for the novice here what exactly does this process do?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
69Cobra is online now   Reply With Quote
Old 05-06-2013, 01:44 PM   #6
afret
Here's some info:
http://forum.lsxtv.com/camshaft-tech...cess-1033.html
http://speedtalk.com/forum/viewtopic...=22563&start=0
afret is offline   Reply With Quote
Old 05-07-2013, 03:55 PM   #7
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
Dave Noll, EF/S ,?/SA 6526
Old 05-07-2013, 05:07 PM   #8
carl hinkson
A P-55 cam core runs up to 20.00 more.
