Old 04-25-2013, 10:16 PM   #1
IT427
Default 9 x 30 Goodyear question.
I've got a 65 ChevyII that I'm building for brackets. I'm currently running a 295/65-15 MT radial for the street/strip. The car is minitubbed, 8-point roll bar, 9" Moser rear with mono leafs and Cal Tracs. I have Calvert shocks in the rear and want to run a 9 x 30 Goodyear slick for better consistency bracket racing. What is a good compound to run, or is there only one for that size tire. Any other suggestions will be appreciated. The car is kind of set up as a Stocker. Dave
IT427 is offline   Reply With Quote
Old 04-26-2013, 08:44 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: 9 x 30 Goodyear question.
I'll tell you what a Stock Eliminator friend of mine told me about those. He says the Goodyears started to slow down after 30 passes or so. He says the Hoosiers last much longer and don't slow down their whole life.
Hope this helps.
Ed Wright 4156 SS/JA
Old 04-26-2013, 08:52 AM   #3
FLEMING
Liked 54 Times in 25 Posts
I have never ran the goodyear but I run both the 30X9 Hoosier radial, and the 30X9 bias hoosier and both will hook till the chords are showing.. My car isnt super fast 1.51 60'..
FLEMING is online now   Reply With Quote
Old 04-26-2013, 09:04 AM   #4
Bob Bender
Bob Bender's Avatar
Liked 459 Times in 90 Posts
Originally Posted by ed wright View Post
i'll tell you what a stock eliminator friend of mine told me about those. He says the goodyears started to slow down after 30 passes or so. He says the hoosiers last much longer and don't slow down their whole life.
Hope this helps.
. X2
Bob Bender 144 O/SA
Old 04-26-2013, 12:10 PM   #5
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 9 x 30 Goodyear question.
X3 on Hoosiers
Don't use radials for local bracket racing. Bias will be more consistent under potentially marginal track conditions. But if you can fit a wider tire, do so. Hoosier has a pretty good variety of sizes.
http://www.hoosiertire.com/specdrag.htm
Old 04-26-2013, 01:37 PM   #6
GTX JOHN
Liked 2,462 Times in 694 Posts
We have run the 9/30 Goodyear for many years.
I run them clear til cord begin to show .. Never slow down.
We have set the Record on a set with very little inspection
hole left.
They also HAVE a 9/30 Bias available but we run the radials on
our both our bracket Valiants because we have no room for
much growth and and bias will rub. We get two seasons
of racing out of them = But we do a conservative Burnout.
I did not see on the posting that he was referring specifically
To Radials.
Old 04-26-2013, 02:58 PM   #7
IT427
Thanks for the quick replies. I don't plan on running a radial, and the Hoosiers sound pretty good. Any recommendation on a compound? D5 or D7? Also I race at Norwalk so traction usually isn't an issue. And I only have a 355 with 12-1 CR and Dart 200 heads, 1.76 PG with a brake and may be switching to alky later in the season. Dave
Old 04-28-2013, 09:14 PM   #8
Liked 10,679 Times in 2,222 Posts
The new compound is doing very well, I have almost 85 runs on my a/sa and still have 50 % tread left. To date I have only spun once and that was due to poor track prep at St. Louis. The compound works very well at Bowling Green at the local combo race and at Sikeston Mo. 1/8 mile bracket track.
Old 04-28-2013, 11:22 PM   #9
Run to Rund
Liked 54 Times in 27 Posts
Hoosier D07 is good for stick cars.
