Old 04-25-2013, 02:45 PM   #1
Peter Ash
Peter Ash's Avatar
Default Re: Fuel Spigot for Fuel Check
I have used a "T" and run the spigot in combination from the 1/8" NPT gauge port.
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
Old 04-25-2013, 03:49 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,959 Times in 593 Posts
I got a push button style fuel check valve from Jegs I think. It has an AN type fitting. Real easy to install and use. I tried a ball valve that worked but one time I bumped the lever on the ball valve and did not notice. Leaked fuel on the starting line and lost the round not to mention the fire hazard. I like the spring loaded button style that I have now.
Mike Pearson 2485 SS
Old 04-25-2013, 03:55 PM   #3
FED 387
Liked 335 Times in 182 Posts
you will need a "flare seal" ORB fitting(EARLS/XRP/AEROQUIP SELLS EM) with a -10 size on the one end or whatever size the regulator is and a NPT either male or female on the other end--- otherwise just get a AN ORB plug and drill & tap it for the proper size NPT thread
Old 04-25-2013, 07:28 PM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 313 Times in 106 Posts
Have LSM fuel check valve, has push button
Mike Taylor 3601
Old 04-26-2013, 01:20 PM   #5
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
Not sure which A1000 you have, but if there's an 1/8"NPT gauge port on it, you can use the Aeromotive 15631 sample valve. I bought one and used it with my Magnafuel regulator...nice piece, plus it has another port for the gauge.
Paul Merolla is offline   Reply With Quote
Old 04-26-2013, 09:35 PM   #6
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
I ordered one from Jerry Bickel. There were several to choose from, they offer NPT as well as AN style. The price was on the level with the rest. MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 04-27-2013, 07:36 PM   #7
Kenney Kelley
Liked 72 Times in 36 Posts
I would buy a -6 straight thread plug from Jegs with a o-ring . Then drill and tap the plug for a 1/4 pipe thread. That is what I did. I think the price was $ 3.99 I hope this helps. Kenney Kelley
Kenney Kelley is offline   Reply With Quote
