Old 12-28-2012, 02:10 AM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default GT 302 info
I have a friend with a 66 merc Caliente that wants to run super stock, I'm thinking the GT 68 merc 302 four barrel is the way to go. What carb is legal with this combo?
2009 V/SA Record Holder
Old 12-28-2012, 10:13 AM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: GT 302 info
Mercury 302 used a little Holley. 1.563 throttle bores, 1.250 primary venturi, 1.313 secondary venturi. Like a "600 Holley" or a model 1850. The factory id was C8OF-D for stick, C8ZF-B for an automatic according to the NHRA tech info. The same engine in a Mustang used an Autolite/Motorcraft model 4300 carb.
http://www.nhra.net/tech_specs/engin...ts/FORD-68.rtf
Old 12-29-2012, 01:03 AM   #3
Phillip marvetz
Finding a original carb would probably be difficult, Would a 1850 holley be a legal substitute?
Old 12-29-2012, 09:03 AM   #4
Dwight Southerland
As long as the throttle bores and venturi size are within the specs of the tech sheet, yes.
Old 12-29-2012, 11:40 AM   #5
Jeff Lee
Jeff Lee's Avatar
Talk to Quick Fuel. If they don't have it, they may make it and put it in their catalog.
Jeff Lee 7494 D/S '70 AMX
Old 12-29-2012, 11:53 AM   #6
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
Quick Fuel says they are available now.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
