#11 |
Liked 346 Times in 126 Posts
If I were you I would just go bracket race that combo and have fun with it. Do all the suspension mods etc and then drop the 302 in it. Spending the money on a header that may or may not work well is just a waste of money.
#12 | |
Marty Knox |
#13 |
You can win with any car,just talk to Lane Weber or a host of other guys here like Mark Y. The problem is you may spend more money than necessary jsu to get this combo run the number
#14 |
Liked 43 Times in 29 Posts
Just make sure this combo has the potential to at least run the index if you are going class racing. Other wise it's just a waste of time and money.
Mark Ruset 2048 STK |
#15 |
Liked 4 Times in 4 Posts
This engine combo can run the index in a Maverick or Comet, I get a slightly better flowing head and a little less weight, so I figure if I'm in the ballpark I *should* at least run the index. I personally think it'd be fun as hell to put a 200 with a 1bbl in the 15's. I like the oddballs. At this point, I have everything but a converter and cam, and by scrounging (thank you CL and ebay) and using some used parts I am in it $1500. Granted that is just collecting parts and I have yet to tear into the motor and trans. I found a header unused for $150. I'll probably start a build blog to share, good or bad.
When someone says why, ask, why not? Last edited by Joe Toller; 08-03-2012 at 12:41 PM. Reason: Forgot a detail |
#16 |
If it doesn't run the number, I can put that 200 in another Fairmont with some more cam and carb on the street and then I'll go 302, but not until after I give the six a fair shot.
#17 |
Liked 27 Times in 14 Posts
My car is not that competitive. I am a 1 of 1 combination. Im usually .3 back of the chebbie guys and V6 other chebbie and pontiac guys. I have a blast, do ok, and did better than was expected first time around when the car was built. Go for it. I seem to recall a rather good running straight 6 in a Comet........... with a stick........
AD |
#18 |
What are you running Capri?
