Liked 7 Times in 6 Posts
Weird deal... I tried another timing set I had in the garage [used, but good shape] I have virtually NO movement at the rotor, when cam pushed or pulled. I don't know how it could be the cam sprocket, unless they machined the part that snugs to the cam thicker. They are both Cloyes multi keyed double rollers.
#2 | |
There are two part numbers for the SBF. |
I believe they are, both the same C609 is stamped on the cam sprocket. I think the problem may have come from the fact that I used a thin washer between the cam sprocket and the thrust plate, it must have come with the T set. I think it ate away at the back of the sprocket. You can see its been shaved down quite a bit. The cam end play with Tset from garage is .006 +-, the one on the car had .09, not .009, but .09! Yikes!
#4 | |
