Old 07-14-2012, 07:31 PM   #1
Liked 5,153 Times in 1,967 Posts
Default Re: powerglide question
Originally Posted by Bobby Zlatkin View Post
But, can both be plugged?
I know this can't be done with a T350, as there must be a loop connecting the two ports to keep the path of fluid open.
However, I've aquired a race prepared powerglide and both ports are plugged. Is this OK?
Bob, both the PG and the T350 have a cooler bypass valve .It is there for extreme cold climates, where the fluid can't be forced through the radiator cooler without putting strain on the pump .
Remove the bypass ball and spring assy., plug the holes, and you will loop the fluid internally.
