Liked 20 Times in 12 Posts
We have broken two of them. The first one was only after about 20 runs on the new trans. We figured it was something freak. So we replaced the arm and bought a spare. One year later in valdosta we had the same thing happen, this time when we looked closer it looked like a casting problem. It snapped the arm off smooth with the side of the trans. The shifting linkage was dragging on the ground. We replaced the arm and have gone on with things. That has been several years and many runs ago. We to have a long shifter on it. I hope it was just a freak thing that happened to you. Good luck.
Liked 56 Times in 29 Posts
Did you carefully adjust the shifter stops?
Liked 57 Times in 14 Posts
You're not alone gmonde. We have been fighting this problem for 3 years now. It was bad enough at one time that we had to bring extra shift levers to the track just to make it through a race. After installing a new one (3/4), it would immediately start twisting and eventually break. When we removed the nut and slid the lever off, the internal hole would be rounded out. Lever was tight, but still moved around. We been through every test imaginable and haven't found a cause. These are the NASCAR hardened, long shift levers. Long shifter, as well. Everything is adjusted properly. Similar situation. We've run the same Jerico for YEARS without fail, then all of a sudden, BOOM, problems around every corner! The one variable you might check is that your bellhousing is indexed properly. If the transmission is misaligned, it will put too much stress on the main shaft and shift forks (and gears), causing the need to use too much force when shifting. We should be out testing in the next couple of weeks. If we figure something out, I'll post it here. Might be time for a Liberty.
Mike Voth 5189 GTN - 5188 GTO Voth Racing |
Liked 2 Times in 2 Posts
I've broke one in the last 10 years. When mine broke my stop had loosened up and was not stopping the shifter, the slider/fork/arm was. After adjusting it on the bench with the cover off and seeing what its doing in there I've not had a problem since. But I believe the key is to set the stops with the cover off so you can see what you're doing. I set mine to where it leaves about .030" of play before "bottoming out" and let the dog ring suck the slider in the rest of the way. Haven't had a problem since. Also make sure your shifter rods are running as parallel as possible. Hope this helps
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 Last edited by 69Cobra; 06-04-2012 at 11:22 AM. |
Liked 165 Times in 59 Posts
i have to ask ,,what lenght shifter (long has a short and long version)and what lenght fork arms are you guys running ???i am thinking the both long shifter and fork arms are creating to much leverage for the ecentric to handle ,,also double checked the adjustment
and mentioned previously the fork slides work perfect as well as the sliding 3-4 dog ring thanks for your replys ,, still investigating gmonde |
#6 | |
Liked 293 Times in 65 Posts
#7 | |
I run the Mr. Gasket vertical gate, aka Hurst V Gate 2. It has a bolt-on set of stops. For the price, the Long darn sure ought to have stops. Apparently it does:
Designed exclusively for G-Force G-101 clutchless transmission. Allows transmission to be rotated 90ยก for increased ground clearance. Supplied with stainless steel tube rods and Heim-end linkage for all applications. Push-pull design virtually eliminates missed shifts. External shift stops prevent overshifting which can result in transmission damage. http://longshifters.com/shifter_4_vj1000.asp Last edited by Run to Rund; 06-19-2012 at 07:37 PM. |
Liked 3 Times in 1 Post
#10 | |
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
