Old 05-27-2012, 05:10 PM   #1
Robert Simpson
Liked 20 Times in 12 Posts
Default Re: Brake pressure switch
Phillip, I tried to order online at GEMS, but it would only allow me to order 10 at minimum. I will try again, that is why I tried to call them. Thank you for the info I will look up the switch you use.
Robert
Robert Simpson is offline   Reply With Quote
Old 05-27-2012, 05:57 PM   #2
Phillip marvetz
Phillip marvetz's Avatar
I ordered four when I bought mine. Even if you had to buy 10 you could probably sell the extrs here,lol
2009 V/SA Record Holder
Old 05-27-2012, 11:39 PM   #3
west coast
Liked 223 Times in 73 Posts
Robert pm me I have had the same problem with min of 10 to order. I need a couple of switches also.
west coast is offline   Reply With Quote
Old 05-28-2012, 02:32 AM   #4
GTX JOHN
Liked 2,472 Times in 696 Posts
I could use a couple or three myself.
Old 05-28-2012, 10:27 AM   #5
Steve Hayward
A good parts guy can find one..... they are preety comment..... I think they are used a lot in tow motors......... I pay about $10 CDN to prob 15 now for one.......
Steve Hayward is offline   Reply With Quote
Old 05-28-2012, 10:01 PM   #6
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Why does this switch need to be adjustable?
If you are using an adjustable switch, must you install a brake pressure guage?
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 05-28-2012, 10:15 PM   #7
KRatcliff
Liked 524 Times in 141 Posts
Adjustable helps you adjust your reaction time. There is a point of diminishing return. I don't use a pressure gauge, but I always check it for muscle memory right before I pre-stage.
KRatcliff is offline   Reply With Quote
Old 06-01-2012, 11:53 PM   #8
bmedeirs
bmedeirs's Avatar
I use a switch from PDI PDAH-4-4M-C-FL-9. There are older versions of this switch that have a similar part number. There are a couple of these currently on ebay.
http://www.ebay.com/itm/PDI-PPDI-PDA...item35ac4b4a0d
http://www.ebay.com/itm/DYNAMIC-AIR-...item1c25be9020
You need a second switch in series on the shifter in first gear position so that the brake pressure will closed the micro switch when you step on the brake at the starting line and the switch on the shifter most be in first gear and closed also for the two step to be activated. This prevents the two step from activating at the finish line if you foot brake at the stripe. I use a common bump switch for the shifter mounted on a small bracket. I brake pressure gauge with a small light built into it is also a good option also. The pressure switch must be installed with the red wire (Normally open) and also the black wire = common. The pressure switch is adjustable, remove the screw from the top of the switch, using an 1/8 allen wrench to adjust clockwise to increase set point and counter-clockwise to decrease set point. Then replace the screw. Works by staging, stepping on the brake hard, stepping on the gas, releasing the brake to launch.
Bob Medeiros Stk #1212 70 Camaro B/SA
bmedeirs is offline   Reply With Quote
