Old 12-04-2011, 10:35 PM   #1
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
Default Re: Is this legal?
Originally Posted by Bob Mulry View Post
I can't take it anymore.......
Panhard bar = poor man's watts link and is ONLY used to latterly locate the rear end housing under the car.......
Sway bar = anti-roll bar = stabilizer bar and it is ONLY used to control body roll by applying pressure across the vehicle.....The body wants to roll but because the bar is attached to the body and the links try to twist the bar to roll.......In some types of racing the racers like to have the links adjustable to pre-load the suspension with out changing the spring rate.......
Same thing with the "anti-sway bars = anti-roll bars = stabilizer bars" that bolt solidly to the lower control arms. The bar will always attempt to keep the control arms parallel and prevent body roll....
i think neveryone but Ed will agree with you, i have never heard a panhard rod called a sway bar,
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-05-2011, 12:01 AM   #2
J&P
Talking Re: Is this legal?
Anti-roll bar = Sway bar ... Check out Jegs an Summit and look for Panhard bar end links. They have them for Sway bars , but, I don't think you will get them to work with a Panhard bar...
Anti roll-bar / Sway-bar controls body roll or Sway
Panhard bar / Diagonal / wishbone / Watts link control lateral movement
Jus sayin.....Pete
J&P is offline   Reply With Quote
Old 12-05-2011, 12:57 PM   #3
CrateCamaro
CrateCamaro's Avatar
Liked 19 Times in 7 Posts
Ive never herd of this either...and ive been across the country at different NHRA and IHRA races and almost all stockers....coil spring or leaf...have an antiroll bar. An ANTOROLL bar does exactly what the factory SWAYBAR does but more efficiently and its way more solid. I could understand non adjustable links in stock because an adjustable link allows you to add preload. A parnhard bar locates the rear end side to side....an antiroll bar has no side to side properties at all...it controls body roll just like a sway bar. Looks to me like some people just like to argue even if they are wrong
Ive bought, built and broke a tonne of antiroll bars and never has the rear tires hit the quarter panel. So having said that it is in no way even close to being the same as a panhard bar. Some people just buy things and bolt them on their car...these are the people who dont understand the terminology and how things work. They kind of understand because of google but thats about it.
Please...i know its the off season and some poeple are stuck in their house and their choices are listen to their nagging wife or go on classracer.com. Im not looking for an aguement here this is my opinion only and im not fingering anyone out. No internet war please.
As for it being legal I think its ok as long as it bolts into the car. Its better than having a cork screwing tire rubbing disaster. It is a traction device just like a stock swaybar is a traction device as well. Id be more concerned about people having adjustable control arms because I was under the impression that that was not legal. But I have seen alot of coil sprung GM's with upper adjustable control arms. And as for the original post they welded in a brace to bolt the antiroll bar in. The car is sheet metal in this area and you cannot bolt an antiroll bar to sheet metal because the floor will buckle. As for the weld rule I would want it to be a bolt on deal anyways that way you can remove it and service the unit in between races.
Tony Valerio 1968 Camaro
1700 IHRA H/CM
1701 NHRA SS/?A
Old 12-05-2011, 02:14 PM   #4
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
it's a no go Pacific Division
same question
Kelly,
On that is not acceptable, for Stock.
Pat Cvengros
Pacific Division Technical Director
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 12-05-2011, 04:39 PM   #5
Ed Wright
Ed Wright's Avatar
Guys, I'm not just trying to argue. I've been in the auto repair business for 50 years, and what I'm calling sway bars have been called that (as well as anti-sway bars) in service manuals since the 1940s and by about every technition I ever worked with for as long as I can remember. Panhard bar is a term I have only heard in the last 10 or 15 years.
You are free to call it what you want. I'm not going to belittle anybody for disagreeing.
Ed Wright 4156 SS/JA
Old 12-05-2011, 07:01 PM   #6
Jason
Liked 6 Times in 4 Posts
Looks like the list of tech guys in "other divisions" who said it was okay to weld in the anti-rollbar is dwindling.
In fact can anyone name any techman who said it was okay? Probably not.
Jason is offline   Reply With Quote
Old 12-05-2011, 07:17 PM   #7
Chris1529
Liked 70 Times in 29 Posts
need Travis' input.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 12-05-2011, 08:28 PM   #8
monahan
Liked 5 Times in 2 Posts
i ran a ajustable panhard bar 3 or 4 years ago was told by n.h.r.a tech to remove it and put the stock back in also run the stock sway bar never had any luck with that trick stuff gene monahan 1021 stock p.s that was at indy
monahan is offline   Reply With Quote
Old 12-05-2011, 10:57 PM   #9
Travis Miller
Travis Miller's Avatar
Liked 276 Times in 27 Posts
Originally Posted by Chris1529 View Post
need Travis' input.
My input is that Pat Cvengros nailed it with his answer. I must also say that I have only seen bolted in anti-rollbars on NHRA Stock Eliminator cars, none that were welded in...because if I had seen one I would have definitely made an issue out of it!
Looks like it might be time to reinstate my disclaimer.
(Disclaimer: Opinions expressed by me on this forum are exactly that, my opinions.)
Travis Miller is offline   Reply With Quote
Old 12-05-2011, 11:11 PM   #10
Barry Polley
Guest
Posts: n/a
If they allow this then I want my wheelie bars back.
