Liked 13 Times in 9 Posts
We had a lot of rain this weekend.... moisture in the dist. cap?
Liked 43 Times in 9 Posts
I checked that on sunday morning after the monsoon. Cap and rotor were in good shape but the wires have alot of miles on them, going to replace this week. I think Billy is right the more I think about it. Probably as simple as leaning it out
Sam Capizzi Jr. 1301 SS/AS 93 Dodge Daytona R/SA 73 Dodge Dart |
What temp were you leaving at?
My 283 is a 10th slower at above 140 temp and feels like two slugs instead of its normal one....
Danny Waters, Sr / 73 Duster "340" |
140 -150
Liked 292 Times in 101 Posts
I say Billy hit it ,the way the air was there 2bbl car definately would been rich with no changes,rich will not let car crank rpm ,plus converter could'nt flash as high as normal due to power down from air.
How much air hurts mid to higher class stocker, add more if you have 2bbl.,smaller the carb the worse it gets. Danny If water temp is that sensitive you may be a shade lean if that little water temp effects you that bad,as temp goes up engine leans more Mike Taylor3601 |
Liked 54 Times in 27 Posts
You might also check fuel filters and fuel pressure.
#7 | |
Liked 419 Times in 85 Posts
with all the two bbl cars I have run I would think more timing would help the car out and be a little less sensitive. I have run 273 2 bbl cars in 10000 foot air with 24 barometer.
#9 | |
Liked 138 Times in 51 Posts
Cold engine needs more accellerator pump squirt or it bogs. Think "choke". Or am I missing something? A long time ago my bracket car ran flat and missed in the upper rpm ranges when the Holley 4 barrel was jetted several steps too rich - at least 4-5 numbers. |
Liked 5 Times in 3 Posts
Sam check/add timing. @ Indy Div. race in 2007 I had dad's car with the bracket engine. Car ran 16.25 on a 15.80 index. I told dad over the phone "it's lazy I think it needs timing" He said it won't pick up .3. Well I turned it up the next morning & the car went 15.802! The next weekend we had a Div. race @ Columbus ( i took the 1.82 glide out & put in the 2.08) the car went 15.60...something. Anyway car wouldn't start @ the scales....checked timing 50degrees total!!!! But couldn't start the car once it got hot. I always run 40 degrees in everything else. (BTW had 32 in car @ indy)
