Old 01-17-2011, 09:45 PM   #1
Rory McNeil
Liked 1,103 Times in 301 Posts
Default Re: 3310 Holley Carbs
Also, the 3310 & 3310-1 have the replaceable secondary jet blocks and are rated at 780, the later (& cheaper versions) 3310-2,3,4 etc use the secondary metering plate and 750 rating. I believe that the later 750 versions also use the Holley manual choke setup, while the 3310 &-1`s that I have owned, always had an automatic choke. Also some of the later carbs used cheap plastic accelerator pump arms, secondary diagpram housings, and manual choke units.
NHRA 6390 STK
M/S 85 Mustang
Old 01-17-2011, 10:09 PM   #2
Jeff Lee
Jeff Lee's Avatar
And if your spec allows a 3310 then you can replace the rear boosters to the drop down for a +30 CFM gain and you can also replace the metering plate with a metering block for easier tuning.
Jeff Lee 7494 D/S '70 AMX
Old 01-17-2011, 10:25 PM   #3
Paul Precht
Paul Precht's Avatar
Liked 324 Times in 120 Posts
All of my 3310-1 780s have metering plates and drop down boosters
