Looking to mix & match front and back halves of older wheels. Has anyone done this first-hand that could offer advice, things to do or not do that may make this a painless experience?? Basically plan to take the inside half of a set of fronts to mate to a set of rear outer halves to make a narrower, wheel with LESS offset. Thanks for any help.
Greg Johnson 3123 STK |
#2 | |
I think you'll just unbolt them and use an aluminized silicon sealant down the middle.
Jeff Lee 7494 D/S '70 AMX |
Liked 16 Times in 11 Posts
Jeff is correct, clean them real good before you put them together. Put a small amt of sealer around the center than go all the way around the seam. If done right they will not leak.
Bob Pagano A/SA |
Liked 858 Times in 234 Posts
The Super Tricks have a square "o" ring around the inside. but it'll probably be dried out and shrink when you take it out.
Try using a high strength sealer adheasive, not just any old silicone , an seal around the o-ring not on it . .......Mopar differential cover sealant works very well. ....Be sure to use a very small amount of antiseize on the bolt shank to prevent reaction between the steel and aluminum. I used to make racing money polishing Super Tricks way back, make sure that you take a good look at all the holes and the inside of the bead for cracks ,since the newest wheels are still going to be at least 30 years old ! Next to Motorwheel Flys ,Tricks are still one of the best looking racing wheels out there. Tom
Liked 3,164 Times in 969 Posts
You have plenty of good tips here; just wanted to add what Bogart told me when I did my old ones. He highly recommended acetone for cleaning.
Liked 6 Times in 5 Posts
Would new bolts be a good idea ?
Liked 772 Times in 192 Posts
Thanks all for your tips, and advice. I knew someone "out there" would come through!!!!
These wheels are going to be used on a new "old" lightweight street toy................. it appears that it's going to be cheaper to play at home in the near future -- he he. Merry Christmas & Happy Holidays to all!!
