Old 08-13-2010, 02:54 PM   #1
C and W Racing
C and W Racing's Avatar
Liked 13 Times in 3 Posts
Default Line lock and Two step in a clutch car
Question, are you allowed to run a line lock and two step at the starting line when you are running a stick shift combo. And if so, can it be wired to a button or does it have to be wired some other way?
Thanks, Chuck
C and W Racing is offline   Reply With Quote
Old 08-13-2010, 03:17 PM   #2
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: Line lock and Two step in a clutch car
I use a 3-step and did have a discussion with Div. 2 tech guys a couple of years ago at Brandenton. I asked to speak to Bill Holt and explained I need a control for the water box, starting line and down track in case something breaks during a shift. He agreed and that was the end of that. No questions in Div. 4 or 5 also no questions in I.H.R.A. Hope that helps.
Reggie Winkles 2650/Stock
REGGIE WINKLES is online now   Reply With Quote
Old 08-13-2010, 03:25 PM   #3
Liked 1,795 Times in 409 Posts
I had an MSD relay set up to work the three step and the line lock in the G/S car. If you held the line lock button, you were on the burnout chip. When you staged, the switch on the clutch pedal switched you to the starting line chip, and held the line lock engaged, so you didn't need to hold the line lock switch. When you released the clutch, that switched you to the high side chip for the run.
Old 08-15-2010, 07:38 AM   #4
acme383
Alan, i too have my car set up that way, but for some reason the burnout limit doesn't work. i thought i followed msd's schematic correctly. any way you could pm me? thanks Dan
acme383 is offline   Reply With Quote
Old 08-15-2010, 09:40 AM   #5
Scotty D
hey guys here is a link to a completely hands free way to hook together a line lock and 2 step made by a guy named rick terry who races stick shift cars in the umtr. go to www.thericksswitch.com
Scotty D is offline   Reply With Quote
Old 08-16-2010, 06:16 AM   #6
Bobby Fazio
Bobby Fazio's Avatar
I wired mine this way and it works perfect. I have to use the clutch to shift so even thought there is a button on my pedal it doesn't activate unless first powered by the button on the shifter. If you need a schematic I can give you one. The only thing is, i have to flick a toggle switch after the burnout which turns the 3 step on so I don't know if you are comfortable with adding another step in your staging process.
'65 Mustang SS/L & L/SA
Old 08-16-2010, 05:33 PM   #7
acme383
the "toggle switch" is the missing piece of the puzzle.
Old 07-10-2011, 11:13 PM   #8
Earle Holt
Liked 4 Times in 1 Post
In stock, is it OK to just have the two-step wired to the button on the shifter?
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 07-10-2011, 11:35 PM   #9
I don't think it is. The rules state that a two step must be pedal activated. Get any clarification in writing from Glendora.
Old 07-11-2011, 12:18 AM   #10
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
I have to agree with Alan on this one!!!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
