Old 06-30-2010, 05:31 PM   #1
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default A Arm bushings
Im looking to redo the front end on my G body , and would like to know about what you like, for front bushings. Ball joints too.
Thanks !
2894 STK
Old 06-30-2010, 05:48 PM   #2
SSDiv6
Default Re: A Arm bushings
Thanks !
Global West.
Old 06-30-2010, 05:56 PM   #3
Del A Lum for the bushings, and Moog or TRW for the ball joints. If you can find a circle track supplier, they've got tall upper ball joints that will help the front end alignment when you launch the car. You might want to look at the control arm shafts that Moog and TRW make for wrecked cars, they allow a greater range of adjustments. You can probably get a lot more positive caster, and keep your camber and toe in closer to ideal at the same time. Check the holes in the frame where the lower control arm bushing bolts go.
Old 06-30-2010, 07:50 PM   #4
Kenny Wigington
That's what i was thinking too. Thanks to you both !!
2894 STK
Old 06-30-2010, 10:10 PM   #5
Alan Warman
Kenny
I just bought the Afco kit, bushings and low friction ball joints. They also have a 1/2 longer top ball joint. The only thing I don't like about the Afco bushings is the top bushing is just a solid bushing with a grease fitting.
Alan Warman
STK 4107
Alan Warman is offline   Reply With Quote
Old 06-30-2010, 10:27 PM   #6
SSDiv6
Originally Posted by Alan Warman View Post
Kenny
The Global West bushings, when installed properly, they will not bind and move freely.
Old 06-30-2010, 10:37 PM   #7
72Malibu
72Malibu's Avatar
I'm just using polygraphite bushings on the upper and lower control arms.
*** 72 Malibu ***
1.329-3.99-6.28@106.71-9.98@131
best 60ft to date-1.2997
72Malibu is offline   Reply With Quote
Old 07-01-2010, 11:39 AM   #8
Dyno
Dyno's Avatar
Liked 687 Times in 205 Posts
Prothane makes some great, easy moving bushings. Look at their website. Dyno
Dyno is online now   Reply With Quote
Old 07-01-2010, 01:08 PM   #9
Greg Barsamian
Liked 427 Times in 97 Posts
Kenny, In addition to what Alan suggested, check out Allstar Performance
(a division of Lane Automotive) in Watervliet MI
They have exactly what you are looking for in Oval-track front-end parts & more!
www.allstarperformance.com.
Old 07-01-2010, 02:03 PM   #10
SSDiv6
For drag racing applications, I will always suggest racers to not use poly graphite or urethane bushings since with time, they will deform and deteriorate. If was to to suggest a bushing, I would rather use, due to its properties, Nylon.
