I have replaced entire brake system on my 67 Firebird. Wilwood disc on all 4 corners, new Wilwood 1" bore mastercylinder that they recommended, Wilwood prop valve. Most of the hard lines are new, and replaced the soft line in rear, and put new braided lines to front wheels. I have checked all fittings, and no leaks.
The brakes are soft. I can pump them up, and get some pressure, and it will stop car. I have the new prop valve with the pressure switch built in, and it is getting pressure with only one pump, but I am not sure how much pressure it takes to make switch. I do not have a gauge on the system. I have only driven it slowly up and down street in neighborhood (open headers, etc. gets lots of attention) to check brakes, bed new pads, etc. I have bleed the lines, and got good clear fluid out - no bubbles (with the new system, there was not any old fluid left anywhere). Feels like I need to bleed them again. I just wanted to run it out her, and see if I am missing anything. Thanks in advance. Ken |
Liked 46 Times in 29 Posts
did you bench bleed the master. did you bleed at the line lock and all connections?
did you gravity bleed before pressure bleeding? push rod adjusted as they recommend? brake pedal rod in top hole of pedal assembly? all pistons coming out evenly and calipers spaced over rotor on center? are they floating calipers? or fixed to caliper bracket? You might need a few more trips to get all pads and pistons on center w rotors. just some things to double check for you. |
Make sure you've installed all the calipars with
the bleeder valve up. At the top. Or you'll never get all the air bubles out.
Bobby & Norene Zlatkin L/SA |
Try bleeding the master cyl at the fittings. If that don't work you could have a bad master cyl. Air will always go the the highest point in the system.
Liked 165 Times in 59 Posts
all points mentioned are things to look at ,, normaly what i do is install the master on the car and bleed it before any lines are hooke up(have a helper in the car)hook up the rest of the system and gravity bleed from each wheel untill no air bubbles are present ,,close bleeders and start bleeding from the right rear,left rear,right front,left front,if the pedal still is spongie there could be several things,,brake pedal ratio to master,,brake pad not seated correctly in the caliper,,you might have to isolate the area by capping the lines going to the front or the rear and then check the pedal for firmnees,,,you should get a presure gauge to see if you getting the proper presure at the wheels
gmonde |
Thanks all for suggestions and help. I put it in right, and have checked most all the things mentioned. Think I am going to just start at the master cyl and start over with it, and see what we get. All "looks" right.
Wonder if getting wife to help bleed brakes on a racecar is a good mothers day gift??? Not sure if this will get worked on today or not! thanks again, and keep the ideas coming Ken |
I assume the pedal is rising after pumping. The posts cover 99% of what I've seen may cause your problem but if you are pressure bleeding the system correctly (closest to farthest point without an "X" system) I would take a real good look at Mr. Zlatkin's post. Also, make sure the master is what you think it is. (1" bore)
Ken , As mentioned..Where is the push rod mounted to the brake pedal?
If it's in the PB position , it needs to come down at least an inch. The leverage ratio and clamping force is actually better with it up high, but the pedal will never feel right to you. First thing to check.
Thanks Mark.
Car was original 4 wheel drum, manaual brake car. Have it in the same hole. Push rod length is good. Brakes are actually soft. At low speeds, have not had it going over about 30, have to pump brakes to get any pressure. Will stop the car, but have to pump the brakes to get pressure. Just feels like I have air in it to me. I pressure bleed them, starting at back pass, back driver, front pass, front driver, and got all the bubbles out, then several shots of good clear fluid at each wheel, before moving on. The Wilwood wheel cylinders have 4 bleeders. I use the top, outside for each wheel... Think I am going to just start at the MC and start over, unless I find something that I am missing. Ken |
You Said "Just feels like I have air in it to me. I pressure bleed them, starting at back pass, back driver, front pass, front driver, and got all the bubbles out, then several shots of good clear fluid at each wheel, before moving on. The Wilwood wheel cylinders have 4 bleeders. I use the top, outside for each wheel..."
OK I believe that could be your problem.... in a fixed/opposing piston caliper configuration with 4 bleeders you usually need to bleed BOTH uppers in each caliper half. (Not just one) |
