Old 02-18-2010, 12:28 PM   #8
hookdaddy
Liked 8 Times in 3 Posts
Default Re: roll bar
Originally Posted by Jeff Lee View Post
so you can place the weight where you want it. Amazing what an extra 50#'s in the trunk will do for traction!
That's probably the best reason for moly. Keep in mind if you got a 1' piece 1-5/8" BAR stock in moly and mild steel they would both weigh the same. But since chrome moly is much stronger the NHRA & IHRA allow moly cages to be made of tubing that is 34% thinner than it's mild steel counterpart (.083" wall vs .118" wall) Therefore a moly cage will be 34% lighter than mild.
Two other things to keep in mind - since moly is lighter - shipping cost on the kit are lass but since it requires TIG welding, unless you can weld it yourself , installation cost are bound to be higher.
Don Scholl
d.scholl@comcast.net
145Y Stock - 145H Super Comp
hookdaddy is offline   Reply With Quote
