Old 01-15-2010, 07:48 AM   #1
Mike Fuller
Liked 192 Times in 76 Posts
Default Moroso Ceramic Engine Seal
Has anyone out there used this product? Does it seal small water leaks as the product description claims?
Mike Fuller 396 STK
Old 01-15-2010, 08:20 AM   #2
Liked 1,778 Times in 404 Posts
Default Re: Moroso Ceramic Engine Seal
Yes, it does. I usually follow it with sodium silicate, found at the local drug store.
Old 01-15-2010, 09:18 AM   #3
Mike Fuller
Thanks Alan.
Mike Fuller 396 STK
Old 01-15-2010, 09:50 AM   #4
Scotty D
in the old days of cast iron headed modified production cars,they bought stock in ceramic seal and usually used it every time the raced.engine builders always said if it didn't leak a little it wasn't going to be fast.
Scotty D is offline   Reply With Quote
Old 01-15-2010, 10:39 AM   #5
Mike Pearson
Mike Pearson's Avatar
Liked 1,909 Times in 573 Posts
Mike,
If you have a crack or hole in the head you wll not have very good luck with any type of block sealer. I have tried them all. Sometimes you can get a temp fix from it. In my experience I have always had to find the cause of the water leak and weld or epoxy the problem. good luck
Mike Pearson 2485 SS
Old 01-15-2010, 03:58 PM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
This is the best product I have found for pesky water leaks in heavily ported heads: http://www.steelseal.com Pricey, but works.
Old 01-15-2010, 07:54 PM   #7
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
There is also a Goodson product we used on my brothers car a few yrs ago. It worked real well. Its a liquid, and I dont think he's had any more issues with it.
2894 STK
Old 01-16-2010, 08:15 AM   #8
Mike Fuller
Thanks for all the advice. First had expirence is the best way to resolve thiese kind of problems.
Mike Fuller 396 STK
